Anyone installed DRL fog light “Fang Lights”?
robfultz
Rob
2024 Tacoma Off Road
Ok. I had the issue with lights coming on randomly. Tried multiple fuses in the fuse box under the hood…no luck.
read somewhere the fuse box under the passenger side dash was the one to use.
Used USB 2.
No more random lights.
TFOUTS
Timothy
Northwest Florida
On this column are 4 20a yellow and 4 10a red fuses. The last one next to the empty slot
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_5008
dvrgz
Los Angeles
Diggin these fang lights. Anybody have them? Tacomalifestyle has no ETA on a restock. Does anybody else make something similar?
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_9590
holden
Holden
Scottsdale
'24 Toyota Tacoma TRD Pro
I would suggest not buying the Tacoma Lifestyle kit. It’s overpriced for what it is. They all function the same but just behind a different name.
These are my cheap amazon versions that I installed myself. I tinted them myself also. The white LED bars were just too much. Needed a more oem look.
They look and function just like the Toyota Lifestyle version. In all, probably about $80-90 spent including the tint.
How did you tint these? I received mine yesterday and I agree the white LEDs are too much.
Novax
Michael
Novnov111!!!
Tacoma 2024
Used USB 2.
Did this work? Because I just installed mine and it turned on randomly and j don't want to kill my battery
robfultz
Rob
Yes, running into the passenger compartment to the USB2 fuse worked.
TFOUTS
Timothy
Northwest Florida
Ever once in a while, the lights will turn on randomly, but they’re only on for a few seconds and then they’re off. I have had the lights for about 2 1/2 months, I’m not worried about it. The photo was just to show where they are plugged in the driver side under the hood fuse box
robfultz
Rob
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_0277
Just run your Red power wire to this firewall behind the battery - There is a nipple there. Nip off the end and run the red wire through it (will need to add a length of wire to make it longer). It will come out right above the interior Fuse box on the passenger side. Attach a fuse tap and use the USB2 fuse.
You will need to remove the panel under the passenger side dash to access the fuse box (4 clips to push and pull down.
The fuse box lid will not go back on with the fuse tap. I just used electrical tape to lightly attach it back or you could just leave it off and put it the cover in the glovebox.
RocktMtnWay_406
Lance
Bonney Lake, WA
2025 Toyota Tacoma TRD Offroad Club Cab Long Bed
I think I am on the same path as you but with ditch lights. Let me know how you've done. I'll let you know if I get anywhere as well.
theDLR
AL
Nevada
2025 TRD Sport
I know someone else had asked earlier in the thread if anyone who installed has their OEM fangs lying around and want to get rid of? Gonna try something different with em in terms of lighting.
Back to the original topic of the thread:
From what I've read through on a handful of posts in this thread is everyone wanting to make them more standard in the basic on off kind of style like normal lights, no special frillz. My guess just in how these lights are wired are using either 1 of 2 LED types. Either the manufacturers are using some time of chip or addressable LED with built in chip to create the effects that everyone seems to love/hate.
But light circuits are pretty straight forward even with LEDs, remove the chip and wire like a regular circuit and you've got your regular on/off. Of course this would involve breaking them apart to even see first what exactly is inside, should some one wanna take one for the team.
BTW this is my first post here on the forum. Still doin a bunch of research and have a few lighting/electrical projects set for my taco.
