- First Name
- Paul
- Joined
- Apr 3, 2025
- Threads
- 1
- Messages
- 66
- Reaction score
- 51
- Location
- NW Florida
- Vehicle(s)
- 2025 Tacoma Limited Hybrid
Thank you!
Search tool works pretty well as well. Also at the bottom of each page there are similar threads.Thank you! I have to apologize also, I'm still learning the nuances of this forum and should have tagged you in the post! Yes, it was directed to you, but was posted as a more general question. Thank you for going back and specifically answering my question.
So @JustDSM, a specific question for you... Since the I-Force Max Hybrid engines have essentially 4 modes (5 if you count Custom) what specifically does the tune do for each setting? It seems the tunes are all more power/performance related, so do they have specific benefits for each settings, i.e. ECO, Normal, Sport and Sport+. Specifically, does it provide for better gas mileage in ECO? Does it turn Normal into Sport, Sport into Sport+ and Sport+ into Ludacris (Telsa reference)? Thanks again for your help!
Thanks again for the follow up and for tagging me this time around!
I’ll do my best to give you a thorough (but digestible) answer. I’ll start with some high-level context and then break it down by drive mode. Just a heads-up — this explanation is specific to our calibration. Other tuners or devices may handle these differently (or not at all), so it’s important to know what’s actually being modified, not just chase advertised performance numbers.
Calibration Overview
At the core of our tuning is the engine calibration, which delivers the increased power and torque. In tandem with that, we revise the TCU calibration, adjusting shift points, torque management, and drivability logic. These changes are modeled together, taking into account the quicker spool and broader torque curve, to ensure everything works seamlessly between the engine and transmission.
All our Stage calibrations (Stage 1, 2, etc.) include these engine + TCU updates. Our OE Spec calibration for SR trims brings them up to SR5/TRD output levels while retaining 100% OEM engine and transmission behavior.
Drive Modes – Explained
Each drive mode (where available) is individually calibrated in our Stage files. The most significant differences per mode are found in throttle sensitivity and TCU shift logic. We retain the OE intent behind each mode, but optimize the behavior to match the increased output, so in essence, you’re getting multiple driving personalities in one tune.
ECO Mode
NORMAL Mode
- Gas Models: Subtle bump in throttle response to make the mode more usable, but still calm and focused on efficiency. Great for daily cruising or low-traction situations.
- Hybrid Models: Factory ECO and Normal are nearly identical, so we went the opposite direction and actually softened ECO. This provides better contrast between modes, especially on slippery surfaces or when fine control is required.
- Common to both: Unique TCU mapping focused on smooth, early shifts and minimal engine load.
SPORT Mode
- Increased throttle response for a more lively feel, but balanced for daily use.
- You’ll notice quicker reaction when dipping into the pedal, without making it twitchy.
- Has its own dedicated TCU calibration as well.
TOW/HAUL Mode
- Sharper throttle mapping for spirited driving.
- A subtle rework of the shift schedule to keep you in the power band longer under load, but still perfectly streetable with gentle input with specific TCU updates.
We currently have three levels of the Stage 1 calibration: "Stock", "Base", and "Enhanced". These levels determine the amount of increase in the drive modes. With stock you can ignore all of the above "throttle talk", the throttle sensitivity remains 100% OEM as the truck was delivered. Base is a more subtle increase, and Enhanced is our standard and recommended setting.
- This is the hottest drive mode in our calibration — designed to make the truck feel like it’s not towing a thing.
- It prioritizes torque delivery and shift behavior under heavy load.
- When used without a trailer or payload, it’s very punchy — some folks love it for that reason, but it’s really meant to shine when the truck is working hard.
- Contains a more aggressive TCU strategy tailored for towing scenarios.
Hope this helps!
Edit: Forgot to reference the Sport+ and other "+" drivemodes. Those will retain the same function as the base setting for that mode. So for example. Sport and Sport+ retain the same settings. There are other settings modified by those drive modes that are not controlled by the ECU specifically.
Stage 1 is able to be run on 87-93Do you need to run premium fuel once you have the tune?
Also, is this better than Peddle Commander?
ECO will have lower torque requests based on your pedal input and should yield you slightly better economy. However, either will do well for commuting.Which mode, ECO or Normal is good for long highway driving like 400 miles road trip?
| Drive Mode | Factory Behavior | After Tune Behavior | Notes |
| ECO | - Throttle nearly identical to NORMAL - Early, smooth shifts - Minimal engine load | - Throttle intentionally softened - Even earlier shifts - Smoother, finer control | More contrast added — better for slippery conditions. |
| COMFORT | - Very soft throttle - Ultra-smooth, early shifts - Light steering and soft suspension (if equipped) | - Slightly quicker throttle to avoid sluggishness - Smarter, smoother shifts - Suspension/steering behavior unchanged | Best mode for relaxed cruising, passenger comfort, and long drives. |
| NORMAL | - Balanced throttle - Calm shifts - Light reaction | - Noticeably quicker throttle - Snappier reaction - Smoother yet faster shifts | Feels more lively but still daily-friendly. |
| SPORT | - Sharper throttle - Later upshifts - More aggressive feel | - Further sharpened throttle - Shift points even more performance-focused | Full tuning applied to enhance driving spirit. |
| SPORT+ | - Even sharper than SPORT - Heavier steering, firmer suspension (if equipped) | - Same engine and transmission as tuned SPORT - Still firmer steering/suspension from factory settings (if equipped) | No further engine/TCU tuning beyond SPORT — but still feels different due to chassis/suspension behavior. |
| TOW/HAUL | - Torque-focused - Holds gears for load handling | - More aggressive torque delivery - Harder holding of gears - Even punchier response | Works excellent with or without trailer or heavy payloads. |
I like that setup. Colored matched makes it look complete.I’m stoked to get the tune done. I tow my camper a good deal and I would live to add a bit of extra power.
@JustDSM, when are you guys going to get your new Atlanta tuner ready to go?
This is a great chart! It really breaks it down for each mode! Thanks for posting this!Okay, after reading and rereading does this sound correct?
Drive Mode Factory Behavior After Tune Behavior Notes ECO - Throttle nearly identical to NORMAL
- Minimal engine load- Throttle intentionally softened
- Smoother, finer controlMore contrast added — better for slippery conditions. COMFORT - Very soft throttle
- Light steering and soft suspension (if equipped)- Slightly quicker throttle to avoid sluggishness
- Suspension/steering behavior unchangedBest mode for relaxed cruising, passenger comfort, and long drives. NORMAL - Balanced throttle
- Calm shifts
- Light reaction- Noticeably quicker throttle
- Snappier reaction
- Smoother yet faster shiftsFeels more lively but still daily-friendly. SPORT - Sharper throttle
- Later upshifts
- More aggressive feel- Further sharpened throttle
- Shift points even more performance-focusedFull tuning applied to enhance driving spirit. SPORT+ - Even sharper than SPORT
- Heavier steering, firmer suspension (if equipped)- Same engine and transmission as tuned SPORT
- Still firmer steering/suspension from factory settings (if equipped)No further engine/TCU tuning beyond SPORT — but still feels different due to chassis/suspension behavior. TOW/HAUL - Torque-focused
- Holds gears for load handling- More aggressive torque delivery
- Even punchier responseWorks excellent with or without trailer or heavy payloads.
That's a sweet setup! I think something like that would work well for me and my adventures. I've been thinking about some combination of rack/RTT or something like a GFC but I'm really reserved on stacking on all the weight full time on the truck. Glad you shared that pic!I’m stoked to get the tune done. I tow my teardrop a good deal and I would live to add a bit of extra power.
Thanks for that. I have an authorized dealer 25 miles from me.Stage 1 is able to be run on 87-93
It does a WHOLE lot more than a Pedal Commander.
I think the only other question is, is there a noticeable difference, if any at all in performance running 93 octane as opposed to 87 octane?Stage 1 is able to be run on 87-93
where did you find those? Our tacoma does not have comfort and sport+Okay, after reading and rereading does this sound correct?
- Calm shifts
- Snappier reaction
- Later upshifts
