More HP: Anyone install a JB4?
JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
Dmartin1013
Dylan
NC
24 Tacoma SR 4WD XCLB
Things like Oil Temperature limiters, Engine Coolant Temperature limiters, Air Intake Temp sensor limiters, Knock Limiters, etc., are all rendered useless when the ECU is unable to accurately sample what is happening inside the engine.
We work with and retain these factory safeguards in a way the external piggy-back controllers cannot.
This is not correct. You are implying that JB4 causes most safety measures to be rendered useless. The JB4 is only spoofing fuel pressure sensor and the boost pressure sensor meanwhile using OBD2 to consistently monitor temperature sensors, air to fuel ratio, ETC.. The JB4 also has its own built-in safety measures to ensure it’s not causing damage. I can agree with you that most piggyback tuners do not have built-in safety measures, but this is one of the very few companies that actually does.
I recommend you do more research on your competitor prior to posting such a reckless uninformed comment. It doesn’t look good on your company to make direct jabs at the competition. It would be understandable if someone asked what the differences between a flash tune, and a piggyback tune are, but no one asked.
DialupDavid
Sam
Minnesota
2025 Tacoma TRD PRO
FYI - Burger Motorsport just let me know my Beta JB4 for my Pro will ship this Thursday or Friday.
I haven’t seen anyone else document one really in the wild, especially an iForce Max, so I might get to be that guy! Will document on the forum for others.
I already run 92 Octane, so should be plug and play.. I’m excited!
R242
Rick
Indianapolis
'24 SR 4x4 DC
I've been running it on a non hybrid 6 speeds for about a month now. Only been on 93 for a week running out old 87. Feels good so far, about what I expected since this is my 3rd manual(first Toyota )with jb4.
Dmartin1013
Dylan
NC
My JB4 should be getting delivered today. I have an SR which is factory detuned 50-60hp “just because”. It should be interesting seeing how the JB4 helps this miserable 228 hp. They claim they should be able to get it bumped up to non hybrid SR5/TRD JB4 tuned power levels.
Terry
Simi Valley, CA
2025 Tacoma
Piggyback controllers utilize a signal intercept method of manipulating the various inputs and the respective output from ECU to achieve their target effect (more boost for example). In order to make an effective change, the signal input(s) to the ECU are “spoofed” or manipulated/clamped to effectively bypass the default limiters and target tables referenced. This leaves the piggyback controller free to control the output.
Where a flash tune, such as ours, is able to natively control the boost for example. While working in conjunction with the factory limiters. No need to manipulate/alter/clamp various signals.
When you have to spoof the input signals to the ECU to reach your targets, you’re effectively eliminating and bypassing the built in pre-programmed safeties designed to protect your engine.
Just to clear up any misinformation, here the JB4 does not "clamp" any signals back to the ECU. Signals are intercepted and offset to provide the desired tuning changes. All factory safety systems remain in place, including warmup protection, knock/timing corrections, engine coolant and charge air temperature mappings, etc.
The key is the JB4 is also sitting on CANbus and is able to read every sensor the ECU can, including internal ECU calculations like torque, fuel trims, and more, to model what changes are needed. And the JB4 independently monitors tuning criteria like boost, timing, AFR, fuel trims, fuel pressure, engine temps, etc, so it can proactively alter its tuning or even disable all together, if something seems off. It's like having a tuner look at your logs in real time every time you floor it.
That said flash tuning can be great and for customers not concerned with warranty or resale value, it can be a great option, especially using an at home handheld device that lets you change maps, flash back to factory when needed, etc.
omar286
omar
Sebas1928*
tacoma
Do you have any output on the JB4 for the SR? how is it? how difficult is to install?
Dmartin1013
Dylan
NC
I have the JB4 for my SR. Terry at burger has me pretty dialed in. Im heavily impressed with it. Well worth the money. It took me 10 minutes to install
LincolnSixAlpha
Phoenix
Thanks Terry, as an end consumer and enthusiast I have used the JB4 product in a past BMW N55 based vehicle with wonderful success. That said, I'm thankful that there's products such as JB4 and OTT that want to provide an increased level of performance out of an "everyday" truck such as our new 24+ Tacoma.
Since I've used the JB4 Product in the past, I will likely go that route, but good news -- everyone has a choice because of these two product development companies. As for me, I'm too lazy to bother going somewhere to get a tune, and simply 15 minutes or less of my time and I have the JB4 up and running. Appreciate the work and efforts of both JB4 and OTT.
Gcat671
Zorts!
Atlanta, GA
2024 TACO OFF ROAD
Has anyone installed a Burger JB4 and tested it out? Would love more power out of this thing, particularly after installing some all terrains. Thanks.
I just installed the JB4 on my 4th Gen Taco.....nigh and day difference. I also installed sxth element intake and AWE catback exhaust. Driving experience jumped up a couple levels for sure! Totally satisfied with JB4
Tacolorado
2024 Tacomo
Looking at JB4, they mention big gains, but I think that is off of the SR. Anyone have a Dyno from tuning a Sport or Premium all gas?
LincolnSixAlpha
Phoenix
I have mine, brand new. Installed it for like an hour or two - took it out. It's for sale if anyone has interest. It's like 3-5lb's of additional boost depending on map, etc.
With the type of driving I do anymore, I just dont need to be racing around.
How did it drive?
