Defects of Tacooma that everyone should look at
Mine is also lifting at the cab end and has that two sided tape under the bed rail, but it is way too warped for it to hold it down. I thought it was just a punt at the factory or port to try to cover up a bad part. My dealer ordered a new one as soon as they saw it, but it is back ordered to hell and back, so hard to say when they will get it.
My bed rail cap finally came in and I installed it myself. I don't think that double sided tape was ever intended to retain the cap, just to align it in the front. There are many plugs fastening it to the bed but only a few in the front, and mine was too warped to stay in place. The new one fits fine and if your caps do not fit your dealer should order you replacements.
Reactions: Kjc
rybern
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
Is the new replacement just like the original one or is there actually an improvement? Do you have a photo of the cap removed or the bottom of the cap?
Anyone’s seat trim pop out when you get out of your truck? I weigh only 160lb and the plastic trim piece separates each time and I have to pop it back
DENNISD
Dennis
Omaha
All that water literally goes into the same gutter that takes the water to behind the front wheels and to the ground, whether it’s the cowl or cowl gap. It is never a totally sealed off deal on any vehicle—it all goes to the same spot. I think people don’t understand this. Watch any video of someone removing a cowl and you’ll see that under it a big gutter. There is no water that enters the bay or the cab through the gap it just drops to the same exact spot and drains out. Purely aesthetic problem.
Agreed.
I am guessing most things that potentially can trap water is engineered to drain. I remember when they painted our house, the paint company mentioned that they would also caulk the cracks. After the caulking, I noticed that they caulked under the ledger board (attached to the house) on my deck. I informed them that this should never be caulked on the underneath side because any water that would get by from the top part of the deck would surely be trapped by said caulk. They reluctantly had to scrape that off. :sunglasses:
I am guessing the same applies to the cowl. While it would be nice if most of the water sheds around it, the water that "escapes" under it would be designed to do as such. Not a major factor and I am sure no harm would be done.
The design is the same, and the only difference is that the replacement is not warped. I do have some pictures of the bottom of the cap and I will post them soon.
Here are a couple of pictures of the bottom side of the bed rail cap @rybern . The front picture shows that there is just one push in clip there, so if the cap warps there is nothing to keep it level. The other picture shows a section further back and there are good many toward the rear. I think there are a total of 13 connectors total and they are on both the bed and fender side of the cap. So it is securely fastened, but not well enough in the front to keep it level if the cap warps.
Slappy
tacoma , highlander
mine is doing that , but i had the front seats redone in 100% leather
guy who did the recover gonna fix it after the holiday i'll get back at you
Interesting - seems like a pure toyota defect - how will he fix it?
DENNISD
Dennis
Omaha
I thoughtt mine stickers are crooked to but now I think it's the shape of the bed
I thought the same thing? Not sure if the stickers can be placed on to make it look straight?
I have stood back and sometimes it looks "straight" while other viewing angles appears that it is way off. From this angle, it appears that it should be rotated slightly clockwise.
SilverSurfer
Tacoma TRD OR Premium Plus
I like that John Deere version in the background. Sticker makes the truck…
