Any Molle panels that work with the OEM Tri-fold Tonneau cover
Romer
Ken
Centennial, CO
I read some posts about Rough Contry working on the 3rd gen
The cover lowers the rails
If not, then you venders here is a market with no suppliers :)
Thanks
Stebo19
So Cal
2024 Tacoma 4x4 TDR Sport Premium Pkg upgrade
following...
Goriders
2024 Tacoma Sport Plus
The tri fold tonneau does lower the rail. By about 3/4”
JimScotty0
The Farm, Central Washington
2024 Toyota Tacoma
I have a 2024 Tacoma TRD Pro with the OEM Tonneau cover and installed the Rough Country "Molle Panel Kit | Bed | Toyota Tacoma 4WD (2024)" on the cab and sides of the bed. The rails remain where they were, but did need to get loosened to mount the panels. There were some tight spots, but not bad. I would recommend it. Much cheaper than many other products and it does look and work well.
rijc99
So this panel will fit with the relocated rail? Asking since the OEM hard tri fold cover relocates the rail down by a little bit.
JimScotty0
2024 Toyota Tacoma
My rails and cover were installed by Toyota, so I don't believe anything is relocated with the exception of the rails being about 5/16th" away from the wall because the cover S hooks are using the same mounting bolts as the rails. All looks to me to be the same for the rails with or without the cover as the cover doesn't use the rails except for the S Hooks mounted underneath. It sits just above the rails. I also use my rails for Bed Tie Down Anchors and they don't interfere with the cover since they don't rise above the rails.
I have the OEM Toyota Tonneau cover and I installed these mollie rails with all pre-drilled holes fitting properly. You will need to drill 1 hole on each side as per their instructions towards the rear bottom on the side panels since there is nothing in the area to hold the molle panel rear bottoms. I am still fitting items on my panels, but I already have a hi-lift, recovery boards, RotopaX gas and water canisters. It is very sturdy and is heavy gauge coated steel.
2024 Tacoma Any Molle panels that work with the OEM Tri-fold Tonneau cover 1748837119552-h0
Good video on how it was installed on a 2024 Tacoma.
Xen
Would you be able to take a pic on the side panels. I wanted to install the bedside panels but I believe it won't fit if the side railing has been moved down, I have an OEM cover.
In bed molle sytems | 2024 Tacoma Forum (4th Gen) News, Specs, Models - 2.4L, Hybrid, TRD Pro, Trailhunter, Off-Road, Sport, SR5 -- Tacoma4G.com
rijc99
Oh wow. There might be two versions of this cover. Mine had to be relocated lower in addition to inward.
Here’s the instructions from Toyota That shows the S hook mine uses.
https://toyotaparts.sparkstoyota.com/install/PT954-35240inst.pdf
The one in the instructions is the type I have.
2024 Tacoma Any Molle panels that work with the OEM Tri-fold Tonneau cover IMG_3849
2024 Tacoma Any Molle panels that work with the OEM Tri-fold Tonneau cover IMG_0341
2024 Tacoma Any Molle panels that work with the OEM Tri-fold Tonneau cover IMG_0342
JimScotty0
2024 Toyota Tacoma
I will go out in the garage tomorrow and take a closer look at mine. In either case, the Rough Country Mollie panels did fit, but they do touch the bottom of the bed which is what I was expecting anyway so it didn't make me believe anything was different or wrong.
Goriders
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
I installed the OEM tonneau cover and it did lower the side rails.
I have the Rough Country cab side molle panel and it fits fine and clears the tonneau cover (the cab rail doesn't get moved with the tonneau cover). I just had to trim a little bit of the bed mat to clear the lower mounting points.
Romer
Romer
Ken
Centennial, CO
Thanks for all the inputs. I have been researching panels. It looks like the front panel is not constrained by the cover since you don't move the rail.
I really liked the Rago side panels as they go the whole side. They are expensive and they have a lot of bolt holes that have to line up so likely not to fit
Since several here had said Rough Country fit, I took a good look at their online photos. It looks like the gap at the bottom is sufficient to offset the movement of the rail.
2024 Tacoma Any Molle panels that work with the OEM Tri-fold Tonneau cover 1749936535910-7o
I liked the Toyota OEM panels. There is a gap at the bottom, but not as big as on these Rough Contries, based on the photos.
So I will order the whole set from Rough Country. I could order a different front but from what I was looking at, they all seem to have the same utility just different styles. I think its better for the styles to match.
Thanks again for the input. Happy to have found a solution
