*UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review
HarryDaHamster
Zimbabwe
2024 Trailhunter
July 23 update:
The springs seemed to settle a bit and it doesnt seem like i'm getting the topping out issue anymore. At this point i'm pretty happy about the spring upgrade but but still upgrade to King or Bilstein in the near future.
Old post:
Now that I’ve logged about 500 miles on the Dobinsons C59-820 front springs (with 2,000 total miles on the truck), I feel I’ve had enough seat time to offer a solid review. Truck is a stock weight 2024 Trailhunter.
Bottom line: I wish I had gone with strut spacers instead.
I chose the C59-820 specifically because they’re supposed to be softer than the C59-822, but they still feel noticeably firmer than stock, not ideal for my preferences. Additionally, I’m now experiencing front suspension top-out more easily than I’d like, which has me second-guessing the decision.
Looking back, I probably would’ve been happier with a quality strut spacer setup paired with extended bump stops. That might’ve delivered the front lift I wanted without the added stiffness or topping-out issue.
Also, in some photos the truck appears completely level but some others it seems to be ever so slightly taller up front. I'm not bothered by that. I removed the ARB Chase rack and intend to remove the spare during daily driving as well. Hopefully that’ll raise the back a tiny bit.
If your goal is improved on-road handling and you don’t do much (or any) high-speed off-roading, these might be a good match. For my use case, I’ll likely keep them on until the Bilstein 8100 external bypass series becomes available.
Next mod, wheels and tires to eliminate the “missed leg day” look.
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7625
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7626
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7627
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7628
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7629
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7630
2024 Tacoma *UPDATED* Stock weight Trailhunter/Dobinsons C59-820 Front Spring Review IMG_7769
Appaloosa2
Nashville Tn
25 Sport LB Premium
Interesting I want to install the All Dogs front springs but want the nicer ride.
Vidman
Rick
Mass
Vidman
Rick
Mass
Thank you.. I had talked to Dobinson about that same thing" they told me I would get 1/2 inch in the front with the 820 spring and 1 1/2 in the rear with the 817 spring..
