Aspire V2 Fang Lights install - 2025 TRD Sport
Iqudayo
2024 Toyota Tacoma
I just finished installing the Aspire V2 fang lights on my Tacoma. Whole install took about 45 min, but 30 of that was getting the factory plastic pieces off and zip tying the wires out of the way.
Legitimately plug and play. Once the Fang light is in the bumper, you untwist the yellow turn signal bulb, take it out of the housing plug it into the female end of the prewired adapter, plug the other adapter end into the truck wire housing and put the bulb back in.
I finished in the dark, so pics aren't great. But will upload new pics later
Fantastic install, now you just need to make your blinkers switch back leds and you’ll love it even more.
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport 20250427_142050
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport 20250427_142224
ThatOneNiko
Niko
2024 Tacoma SR5 4WD, 2023 Tesla Model Y LR Dual Motor, 2021 Kia Seltos S FWD
What product do you use for under headlight thingy? I have lasfit switchbacks for my turn signals. I want to make it stock looking and yours look sharp. and are they Plug and play type too?
Iqudayo
2024 Toyota Tacoma
Plug and play e-bay
For Toyota Tacoma 2024 LED Front Bumper Fog Lights Driving Lamps DRL Turn Signal
TheZMaster
Zach
Cheyenne
2025 Tacoma Sport
Did you use any tools to pop the factory pieces off or just hand only? Any tips for getting them off? Did you have to mess with fuses or anything or is it truly plug and play?
TheZMaster
Zach
Cheyenne
2025 Tacoma Sport
Plug and play e-bay
Iqudayo
2024 Toyota Tacoma
you can do a search there is someone here that did an installation video, or check you tube
Unless you want to break the tabs on the OEM pieces, I would suggest just taking the front clip of the truck off. It's an easy job to do if you watch a video how to do it.
TheZMaster
Zach
Cheyenne
2025 Tacoma Sport
I watched it, he made it seem easy to get those factory pieces off but everybody is saying how hard it is. I saw he messed with the fuses too but he didn't have the plug and play type. If you have the plug and play type, do you still have to do anything with the fuses?
Iqudayo
2024 Toyota Tacoma
I watched the video and did what he said yes it does tap to the fuse box.
It was relatively easy
Thew_Tang_Clan
Matt
New Jersey
2025 Tacoma TRD Sport
I did not, I just jammed my arms down behind the lights and worked them free...scratched the sh*t out of myself. Someone up thread suggested using a Hole saw bit for your drill, which I am upset I didn't think of. I wasnt keeping the plastic pieces, so I should have just cut through them.
Thew_Tang_Clan
Matt
New Jersey
For the Aspire lights...there is a fuse splitter on one end. You just pull the fuse (the instructions indicate which one), put the splitter in and put the fuse back in on top. I did cut a hole and feed the wire through the plastic box that the fuses are in (like in the youtube video posted)..just to make it look cleaner, but it was a 30 second thing.
Lolitskasey
Alaska
2025 trd pro
Does anyone know where the turn signal plug is located on a 2025 trd pro i cannot find it to plug the signal part of this kit into
Thew_Tang_Clan
Matt
New Jersey
Take the actual turn signal bulb out of the light. The remove the bulb, plug this light in and plug the bulb into this lights connector.
(Assuming that is what you were asking)
Lolitskasey
Alaska
2025 trd pro
On the 2025 pro it's a built in led strip so I dont think there is a actual bulb.
