Sway Bar Disconnect - Is it possible to add this on later?
turnermier
oregon
25 trdor hybrid
I tore open the back to look for ECU wiring and I cant find it... unless the wiring is not terminated and just wrapped in electrical tape..... ... It has to be somewhere because I dont think toyota used separate wiring harnesses, it wouldn't make sense. hence the button wiring is present
It should be here, but all I found was this extra blue connector which doesnt have enough pins to be the stabilizer ECU
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753925189144-yq
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753925238855-lc
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753925282816-pt
Connector should look like this
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753925353092-07
So we are truly SOL unless it's really hidden..
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753925252186-ia
iron.head
Michigan
2025 Tacoma TRD Off-Road Premium
Somebody said the way Tacoma 4G is designed it will be really easy to add an aftermarket sway bar (disconnect). So somebody will probably come out with a nice one in 1-2 years.
FYI here’s my mechanism, shows some of the wiring.
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? IMG_6414
I’m going to add sound deadening to the back in about 3 weeks I’ll take some pictures then. Let me know what you’re looking for?
iron.head
Michigan
Hi @turnermier . great research.
can you find out what is this part doing in a 2020 4runner?
https://www.toyotapartsdeal.com/oem/toyota~computer~stabilizer~89271-60031.html
the part number for 2024-2025 Tacoma with SDM is also 89271A.
iron.head
Michigan
@turnermier i did some research and the "Instrument Panel Wiring Harness" is separate from the "Wire, Floor". the SDM switch is on the "Instrument Panel Wiring Harness" which should be same for non-SDM and SDM Tacomas.
The "Wire, Floor" is the harness that has the connector for the SDM ECU and there are several part numbers for it. and then there is a "Wire, Frame".
look for 82161-AK250, 82164-AK130. there are like 20 part numbers for "Wire, Floor" and "Wire, Frame". it's not too difficult to swap this harness but at what cost! this project will need a donor Tacoma with SDM. And then there might be an aftermarket solution which will be much easier to install in maybe 1 year.
Michael
25 Tacoma Off Road
Found a OR available but without the SDM. Wondering if I can add this later? Does anyone know if that is possible to do at the dealer or aftermarket?
It can absolutely be added later! Toyota already has all the wiring in place! If you lift up your center console there is a wire harness hanging for the disconnect that runs underneath the frame.
Is the entire front axle that will need to be replaced.. Plus it comes with a skid plate that goes over top of the front axle..
But I can't imagine they'll make it available anytime soon they're going to need them for the first few years of trucks warranty replacements before they start putting them out to the public for add-ons
turnermier
oregon
25 trdor hybrid
Even if you were to install the correct wiring harness and add the ECU, and the actual mechanism you still have a roadblock with marrying the SBD ECU to the main ECU.
We still don't know if this is possible within GTS+ (previously called Toyota Techstream)
After that's all said and done the factory system still would only let you use it in 4Lo which makes aftermarket options much more appealing.
I think if I was going to do it, I would just get the factory sway bar disconnect motor and sway bar from a junkyard and hotwire it to a relay and switch. Of course this removes all aspects of safety but it means you could use it at any time.
iron.head
Michigan
what makes you believe that SBD ECU and the main ECU talk to each other? I know one popular aftermarket manufacturer is already working on a 4G solution.
Michael
25 Tacoma Off Road
No it's all built in to the model
My guess is your thinking of something like people trying to add crawl control to a Sport.. .
The only time you're going to have an issue with the ECU is if you're trying to put something where it doesn't belong...
Michael
25 Tacoma Off Road
Also I don't know who told you you can only use it in four low but that is absolutely incorrect you can use it in two-wheel drive. The limit is the speed... it will automatically reconnect over 18 miles an hour which is actually a pretty great feature
iron.head
Michigan
if the 2 ECU talk to each other, there is a possibility that there is a feature flag in the code of the main ECU that is set based on the stabilizer bar being installed at the factory or not. imagine seeing an error message flash on the screen or an OBD code that stabilizer is not detected / electrical failure. what @turnermier mentioned is enabling that feature flag on the main ECU via Toyota software.
Michael
25 Tacoma Off Road
Are you just trying to argue? Your thought process doesn't even make sense
