The last great 4 banger
BAQ717
ā€˜24 Tacoma TRD OR
Updating the build
Done:
15% Ceramic window tint all around
Satin black roof/pillar/mirror wrap
front end PPF
285/70/R17 Falken Wildpeak At4W
285/75/R17 Falken Wildpeak AT4W C Rated
King front/rear shock kit
Icon UCAs
Rave offroad black wheel trim on one side of vehicle cause thats a PITA
17x8.5 Matte Black Wheel RRW RR7-H Flow Form 6x5.5 0
Triplealiners interior floor mats
Plastidip front emblem
King rear sway bar end links
Spray paint that big ol exhaust tip black - Switched for a dump tip from ATH
Rough Country color matched sport fenders took these off because they took away from clearance and added Rokbloks high clearance flaps. These are perfect for coverage on wider setups. May adapt fenders later but could only use due to mounting.
Rough Country rear shackle kit
Rear seat delete/storage setup
DV8 Offroad Centric Front Bumper with - DV8 Winch, 3" Ambers and 20" Spot
Diamondback HD
Boundry Truck Rack
so I had found a really low pro bedside but it fell through due to vendor. With most bedsides at 5ā€ high there just wasn’t enough clearance for gear. I bit the bullet and added:
Smartcap Adventure
Decked drawer
Decked 1500 slide on top
With all the weight this truck was looking dumpy in the rear. Got the :
Icon rear overland +600 .5ā€ coils
Sits perfectly .5ā€ higher in rear and didn’t look too bad even with a 8000# dump trailer.
I also added the Keko bed dust seal kit. Worked perfect with the DB and so far good with cap. Most of the dust gets in on the sides of the tailgate.
Need to install all of my Meso lights and get my bed geared up. The slide takes a lot of room but is really heavy duty and still has more room above it in the cap than I had under the diamondback with no slide.
I have full truck and smartcap racks coming from UpTop overland with their LED side lights. This thing is gonna be a tank.
Nice build. Curious since it seems that you do some legit off roading. How has your transmission held up? Are you getting a lot of overtemp warnings like I’m seeing others have on here?
grizzlyoutlaw
grizzlyoutlaw
MTN WEST
TACOMA
yup. overtemp warnings on hill climbs and just had it after some towing. Have never seen anything like it. Im not gonig to dump the truck but I will jump when aftermarket coolers come out.
Done:
front end/sides PPF
Icon UCAs
dump exhaust tip from ATH
Rough Country rear shackle recovery kit
Goose Gear rear seat delete/storage setup
DV8 Offroad Centric Front Bumper with - DV8 Winch, 3" amber fogs and 20" amber spot
Diamondback HD
Boundry Truck Rack
Smartcap Adventure
Decked drawer
Keko bed dust seal kit. - a must for dusty roads - beside the tailgate is a huge gap
Also added this year:
OTT tune
SXTH Element intake
Both are a must do. More fun to drive and the turbo sounds awesome.
To install:
Meso lights all 3
Uptop Overland cab and cap racks with pod lights
DV8 center console molle
BAQ717
ā€˜24 Tacoma TRD OR
I would send the invoice for the trans cooler straight to Toyota. 🤣 I also enjoy my truck and don’t plan on dumping it but they need to figure it out with this transmission issue.
turnermier
oregon
25 trdor hybrid
Can you share how you installed the Keko tailgate seal? I cant figure out how it goes
grizzlyoutlaw
grizzlyoutlaw
MTN WEST
TACOMA
You and me both! Instructions were incredibly vague. finally found a picture in another group that cleared things up.
turnermier
oregon
25 trdor hybrid
Thank you,
Turns out the automatic tailgate hates it..a lot.
Even with the bottom strip removed.. sounds like the motor is going to break had to take it off
grizzlyoutlaw
grizzlyoutlaw
MTN WEST
TACOMA
Updating the build
Done:
front end PPF
Icon UCAs
Diamondback HD
Boundry Truck Rack
Smartcap Adventure
Decked drawer
NEW:
Installed my UpTop Overland racks on the cab and cap. I still need to wire the lights in. After some testing I decided I am going to add a cabinet to the driver side of the cap and setup a dedicated electrical/charging station. May add a passenger side cabinet because I am finding that it still takes me too long to get everything out and setup. I also used a Kelty roadhouse tarp and freestanding solar panels. I need to get all the elctrical out of the rear seat because after all this I still dont have a good fridge solution.
Updating the build
Done:
front end PPF
Icon UCAs
Diamondback HD
Boundry Truck Rack
Smartcap Adventure
Decked drawer
NEW:
Do the rokblokz flex properly over terrain ?
