2024 TRD Pro Battery Type
Billy K
Billy
St Louis area
2025 Tacoma TRD Pro, 2008 Rubicon
I’m pretty sure the consensus is that it’s not AGM but I haven’t learned much about batteries yet, I’m just happy my truck started after sitting for a week and a half
The label says "do not tip or open". I think that implies a standard flooded battery. The AGM type is still lead / acid chemistry, but the acid is in Absorbed Glass Mats (AGM) so it does not spill if tipped on its side.
Halifax, NS
2025 TRD Pro
Yeah I’d like to get a new battery some day, but I’ll be running this until I gain more knowledge or this one fails me
That is what I am doing too. So far my puny battery still starts my truck and I have a jump pack in the glove box for when might not. I will report what my dealer says after it is there for service in a few weeks.
HarryDaHamster
Zimbabwe
2024 Trailhunter
Thanks for that pic. Did it look like there's a little additional space length wise for a H7 battery?
Halifax, NS
2025 TRD Pro
Sorry I have no idea what I'd be looking for regarding batteries, I can do a lot with a vehicle and rebuild engines but I haven't gotten into learning about batteries
k1m
Nathanial
usa
According to Optima's website a DH7(deep cycle H7) is a perfect match for a Tacoma hybrid.
As a side note, in the past three weeks my factory battery has been sitting at 11.4 to 11.8 every time I have tested it. It doesn't matter how long I wait to test it (1 hour, 1 day, 3 days). So, bad battery folks (I hope!). I have scheduled a battery test with my 10,000 mile service at the dealership coming right up.
I'm surprised your truck is still starting with such a low state of charge. I drove 5 hours of mostly highway today and mine is sitting at 12.3 volts, which is actually higher than normal. Keeping a battery at that low a charge will eventually kill it, and it sounds like yours might already be toast.
I'll be interested to hear what your dealer says. Mine is going to the dealer in two weeks and I am expecting them to tell me that is normal. I see a DH7 in my truck's future because in my experience they can handle not being kept properly charged much better than a regular battery.
k1m
Nathanial
usa
Yeah. I’m carrying a portable starter pack for the inevitable. I’ve been obsessing about this thing for quite a while (my thread post history will back me on that) and this thread prompted me to go to a direct measure of the battery at the terminals. I was stunned. Hopefully there is no issues beyond them just popping a fresh one in. And yeah, Optima is in my future. My last vehicle had a yellow top. It takes a beating.
Yep - my jump pack is in my glove box because it is just a matter of time until the battery gets so low the truck won't turn on. My wife's Lexus BEV SUV discharged its battery, the dealer tested the battery and it was fine. Their only suggestions was that she needed to not stay logged into the app. That works, but it makes me think Toyota has charging problems with the 12 volts in their electrics and hybrids, because I don't even use the app.
I can charge my battery to 100% with a charger but the truck does not keep it there. Over a week or so it always goes back down to 12.1-12.3 volts. I hope it is the battery, but think it is the truck, and I'll see what my dealer says. I have history with yellow tops and they are great, but I shouldn't need one on a one year old truck.
k1m
Nathanial
usa
..but I shouldn't need one on a one year old truck.
Agreed. My last car, a 2008 Corolla had its original battery last 8 years. A one year old car shouldn’t be an issue. After the factory warranty doesn’t cover this anymore I’m gonna put in a yellow top, something I don’t have to worry about. A new vehicle shouldn’t make me stress everyday. 🤣😭
Rubenc87
Ruben
2025 TRD PRO
I was walking around my truck and I hear something on under the bed of the truck. Not sure what is causing it but if that continues that would be a reason for the battery to drain.
Oh yeah, these trucks do all kinds of things when they are not running. That makes it even more important that they keep the 12 volts fully charged IMO. My battery is never above 12.3 volts, even after a full day of driving, so it doesn't take much to run it down.
k1m
Nathanial
usa
I finally had my 10000 mile service today. I asked to have my 12v battery checked and had the dealer argue that the low voltage was fine and I didn't need to have the battery checked. I insisted. When I picked it up the dealer then told me the battery was 0.10v out of range and they ended up having to replace it.
The dealer then reemphasized that 11.8 is considered in-spec!
TLDR The hybrids 12v system doesn't mean 12v.
Total BS on a 12 volt being fine at that charge level. If that is in spec how long do they expect a battery to live with a SOC below 12 volts?
Mine goes to the dealer in a couple of weeks and I expect to hear the same thing. The low charge is most likely what killed your battery, but at least they replaced it. I will eventually get an Optima yellow top which can handle that abuse, and add this to the con column as I consider how long to keep my truck. My truck is one year old and I carry a jump pack so I can count on it starting. Pretty sad IMO.
Rubenc87
Ruben
2025 TRD PRO
I will have to check the current voltage on my battery. I haven't hit the 5K miles yet. I will take it in for sure when I hit the 5K.
