4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits
DogsandaTruck
DFW
Icon has a mono tube and a bypass version available that I think are 2.5 inch tubes,
King clearly has setups,
Dobinsons has a monotube and a resi version with a 2.6 inch,
Eibach has 2 inch mono tube all around and an upgraded monotube up front and resi out back.
Ive heard Fox has their offering slowly releasing, maybe just presale?
I'm doing a ton of research. My front end is so heavy after my bumper, winch, etc. that I need to get another inch and a half or so to get back to level and gain some of the travel I lost. It also rides ROUGH.
Anyone running the Dobinsons or the Eibachs?
Holley Performance Brands
Bowling Green, Kentucky
2024 Toyota Tacoma
The ADS MESA Series offers a front coilover with an IFP 2.5 Shock body, and a IFP 2.5 Shock for the rear. This provides increased fluid capacity and resists shock fade, resulting in increased performance.
Additional Features:
  • Black anodized billet aluminum top and bottom caps
  • 0.875-inch diameter Hard-chrome plated steel shock shafts for superior corrosion resistance
  • Fully rebuildable
  • Made in America with American components
https://holley-community.com/ADSMesaShocks_ADS2578_Tacoma4G
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits 693742dc7b6d109a560a7da1cf2e262cf9fab763-1
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits ae120f05d66f46223131694777d603bb74a9104a
nickd
Nick
Vancouver
2024 Tacoma TRD Sport, 2008 E90M3, 2020 Tesla Model Y
Here is a before after picture of installing a rough country 1.5" levelling kit on the front of a 2024 tacoma TRD sport. Stock rear suspension.
Make sure to get an alignment afterwards. The camber and toe were out pretty far.
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits IMG_6774-COLLAGE
reklov
@VentureOutTRD
Pacific Northwest, USA
2024 TRD OFF-Road Premium
I ended up getting the Eibach coilovers with reservoirs and the bumps and turns are so much smoother in my offroad. I still need to adjust the front to level out the front. The back is still 1" taller.
AZTaco01
Edgar
AZ
Toyota tacoma
I had the $500 Westcott kit for about a month. I was not happy with the ride and had it removed.
I bit the bullet and had a complete set of front and rear King 2.5 shocks and sway bar links installed. The shock upgrade made a night and day difference in the ride. Buy once, cry once.
How’s the over ride with OEM vs aftermarket is it harder or smoother?
tkrum015
Ted
Olympia
I put the RC front 1.5” leveling kit on mine. Easy to install and looks good. I did have it aligned afterwards to insure it was good
Do you still have the alignment sheet of the before and after numbers?
tkrum015
Ted
Olympia
No springs in the front to level just front and rear shocks and sway links?
Gibbs
Lilygrace0!
2024 Toyota Tacoma TRD Sport
Quick question on the king lift kit, which I’ve been looking at. Is it right that it lifts the front by up to 2 or 2.5 inches but nothing in the rear unless you pair it with a new coil spring?
Drifte
Colton
Iowa
24 Tacoma, 20 RAV4, 10 Tundra, 99 C5
All dogs spring kit was perfect for my needs. Takes maybe a couple hours to swap the springs, and then get it in for an alignment because wow it was off. Factory tires still on, frame sliders do kind of make the truck look lower so worth taking into account visually.
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits Taco-u
2024 Tacoma 4th Gen Tacoma Aftermarket Lift Kits and Leveling Kits alignment
kefferjoe
Joseph
Tempe, AZ
2024 TRD Sport Premium
Yes the only thing that lifts the ring is the springs. Springs are cheap around $250 I would opt for them and you don’t have to go icon it can be any brand
