Any Trailhunter Owners in Utah to help Rokblokz make mudflaps?
Halifax, NS
2025 TRD Pro
Those look like the rally series but good to see they have something coming
Halifax, NS
2025 TRD Pro
Does anybody have the part number for the bolt clips that hold the mudflaps on? I smoked about every one of mine installing the Rokbloks hardware
In case anybody else destroyed the screw grommets installing the wrong mudflaps on their truck this only applies to the TRD pro and TH I'll assume these are the direct replacements from AliExpress. You have more than enough room to add longer versions of this clip but these are the OEM size
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? IMG_4965
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? IMG_4966
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? IMG_4967
RESQCAT
Dennis
North Bend, WA
Did they mount inside? On other trims, Rally mounts inside and High Clearance mounts outside to accommodate aftermarket wheels/rims that are not OEM size.
YukonTRD
Whitehorse, YT, Canada
2024 Trailhunter
JUST installed on my TH. Definitely expensive, especially when shipped to the Yukon in Canada ,but SOOOOO worth it!
Running 35x11.5r18 Wildpeaks, removed the crash bar, have the ARK crash bracket delete and had the ARK full mud flaps. The tires were rubbing/catching on the mud flaps.
The way Rokblock designed this system allows for FAR greater clearace in the wheel well, and now I have no rubbing :)
slater
san diego
2024 tacoma sr5/2wd, white
I give you the RokBlokz high clearance mud flaps, and I'm highly impressed with the look and quality! I was told that it'll be 2-4 weeks for them to be available to purchase, but that it may be sooner since its pretty similar to the other trims.
Good on you for going with the high clearance, I love how theyre larger / wider & gives protection on the sides....
EVERYONE is afraid of them, I think there sexy....
Ive got them on mine & only heard of one other person besides you that went that route....
Nice flex on the color.
Few questions. Are the screws stainless or black? Some pics show stainless others show black. I prefer black. Does the high clearance part hit the truck's metal? Do they flex off road? Do they use all the original bolts holes of the truck?
YukonTRD
2024 Trailhunter
Screws are not black, but have a black washer.. the front flaps do not come in contact with the fender.. yes they are flexible.. yes all original holes are utilized.
airxmarshall
Marshall
Utah
I've attached pictures to show what I have. Keep in mind that my truck was used for the mock up, and they may have changed the hardware since. Looks like they used a mixture of both on mine. They dont touch any metal, and they definitely have flex! They're designed right and the folks at RokBlokz have personal experience with off-roading and didn't skimp on quality. They do use the OEM holes, no drilling required.
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? 20251023_094018
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? 20251023_093953
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? 20251023_094007
2024 Tacoma Any Trailhunter Owners in Utah to help Rokblokz make mudflaps? 20251023_094000
