Mudflaps for Trailhunter?
trailhunger
2024 TH
I have appreciated the various 'mudflap' discussions. Last week, I received a Canadian set of OEM mudflaps and installed on Riddick, our TH. Very happy with them cosmetically. Stupid-easy installation. And look forward to seeing how they perform.
Separate note, also very happy with the bed step. Frequently in/out of the bed, that's become worth every penny. Even with a nice dealer discount compared to list, still pricey, but very happy I have it.
Are those the ā€œmud guardsā€ or mud flaps entirely different part no.? My TH came port installed with the mud guards, love them, barely notice they’re on there.
I also have been rocking the bed step / ordered the SXTH element rear recovery hooks with the bed step relocate bracket (so both rear points can install).
TrailAdventurer
JT
Canton, MI
Hi,
If you've a link for the relocate bracket, I'd be interested. Between the remaining recovery point and hitch, I'm ok with losing the one recovery point. But I'd certainly like to regain it if possible. That bed step though clearly offsets the loss of '1' recovery point for me though.
As you'll find sprinkled about in other mudflap reviews, the OEM mudflaps come in different widths. I don't know what the thinking was behind the OEM US ones. Use this for the wider Canadian-spec mudflap: PK389-35R55-P1.
3 screws each. Took me ~30 minutes to install all 4. There's no rain in our forecast, so it'll probably be a while before I find out just how good they are. Of course, winter and salty roads is just around the corner :*( so there will be more than one way to assess, soon :).
YukonTRD
Whitehorse, YT, Canada
2024 Trailhunter
Canadian here.. these "Canadian" mud guards are not as great as people think, in my opinion. Within 2 weeks of in-town driving, with stock tires and setup, the front-side of my rear fender flares were showing signs of being peppered with rocks.
The ARK flaps are better, and I'm even happier with the Rokblox.
Franko Manini
Frank
Victoria, BC CANADA
Over the weekend I installed the Ark mudflats specifically designed for the Trailhunter (and TRD-Pro) and the wider fender flares. I like the look of my original Canadian factory mudguards, and the Ark guards are definitely a different look. I’d say I like them about the same. The catch is that the Ark flaps offer slightly better coverage, which I think is worthwhile. I took some pics to illustrate the difference. I hope they are helpful to someone:
Here are the OEM Canadian mudflaps:
2024 Tacoma Mudflaps for Trailhunter? IMG_5253
2024 Tacoma Mudflaps for Trailhunter? IMG_5254
2024 Tacoma Mudflaps for Trailhunter? IMG_5255
2024 Tacoma Mudflaps for Trailhunter? IMG_5256
2024 Tacoma Mudflaps for Trailhunter? IMG_5258
2024 Tacoma Mudflaps for Trailhunter? IMG_5208
Here are the Ark mudflaps for Trailhunter and TRD-Pro:
2024 Tacoma Mudflaps for Trailhunter? IMG_5266
2024 Tacoma Mudflaps for Trailhunter? IMG_5267
2024 Tacoma Mudflaps for Trailhunter? IMG_5265
2024 Tacoma Mudflaps for Trailhunter? IMG_5264
2024 Tacoma Mudflaps for Trailhunter? IMG_5260
2024 Tacoma Mudflaps for Trailhunter? IMG_5257
2024 Tacoma Mudflaps for Trailhunter? IMG_5262
2024 Tacoma Mudflaps for Trailhunter? IMG_5261
2024 Tacoma Mudflaps for Trailhunter? IMG_5259
trailhunger
2024 TH
Hi,
I’m assuming the bracket works with the ARB recovery points… You’ll want to call them to confirm. https://sxthelement.com/products/2024-tacoma-bed-step-relocation-bracket?_pos=4&_sid=a217917d7&_ss=r
TrailAdventurer
JT
Canton, MI
Yes, helpful, thanks. If the 'canadian OEM' flaps don't work, I'll go with the ARK. I hadn't seen images presenting them quite as well as yours do. I'd have likely gone ARK had I seen them.
I figure, try what I have for a while, change if needed. Fortunately, as upgrades go, they're not particularly expensive.
Thanks.
Franko Manini
Frank
Victoria, BC CANADA
Thanks.
I agree with your logic. I can't say the Canadian flaps "don't work" but I don't think they're quite as good at keeping the rock chips down as the Arks will be. I'll find out soon I suppose.
What size are those tires? Because I cannot get my front tires to clear those Canadians at even half lock... they have a weird bulge that hits my tire pretty quick. I am running 285/70/17s.
Your tires are 275/70/18 which is nothing too crazy and roughly a similar size to mine …. šŸ§ā€¦ and my caster is about normal so I’m utterly perplexed ..
TrailAdventurer
JT
Canton, MI
Correct, Mickey Thompson - 275/70 R18. No problem whatsoever. Marketed as a 34, like all tires they're smaller than advertised, and are 33.3" actual.
2024 Tacoma Mudflaps for Trailhunter? 1758156746823-mk
rchrds
TN, USA
TrailAdventurer
JT
Canton, MI
First time down a muddy road since I put the new OEM flaps on. As suspected, they don't come down far enough. I like their appearance cosmetically, but functionally zero-value today.
This weekend, we'll be in the eastern end of Michigan's Upper Peninsula. Likely encounter some heavier mud. See if there's any difference.
2024 Tacoma Mudflaps for Trailhunter? IMG_8283
2024 Tacoma Mudflaps for Trailhunter? IMG_8286
2024 Tacoma Mudflaps for Trailhunter? IMG_8284
TrailAdventurer
JT
Canton, MI
<snip>
Got a notification from SXTH that the relocation bracket is now available—just ordered one. Will post an update once it arrives.
From the images, it looks like the bracket shifts the step outward by about 2". Even a 1" shift would be a good improvement. With larger feet or heavy shoes, the stock position feels a bit too tucked in. Moving it out an inch or two should definitely help.
trailhunger
2024 TH
Got that email too! I have the alloy recovery hooks and the relocate getting shipped soon I hope / ordered back in August!
I went with the SXTH recovery points as well because of weight - 6lbs vs the ARB OE @ 20lbs—that’s 2/3rd the weight of my Dometic fridge lol - for some tow hooks SMH
I am building up a ā€˜Diet Trailhunter’ so payload is top of mind these days…
