Passerby Highbeam flashing
TheGreatWhiteNorth
Alaska
2024 SR5
Anyone else getting obsessively flashed by oncoming vehicles because they think you have your highbeams on due to the ultra bright projector headlights?
I've lowered the lights a few notches to try to mitigate it, but 1 out of 5 cars still highbeam me upon passing eachother. Winters are dark and long up here in AK, this is going to be rather annoying. :)
hagglethorn
Russellville, AR
2019 4Runner, 2004 Yamaha FZ1, 2022 Kawasaki Versys SE LT+
I’ve only had the truck for 4 months, but that’s never happened to me.
FishTacos21
Illinois
I've gotten it a couple times since I got the truck in June. I also lowered the lights a couple notches thinking it may help. The previous owner put in different bulbs which is probably the issue. I asked a couple friends if the lights seemed bad when looking head-on and they said they were bright but by no means were they blinding.
TX-BluStreak
Houston
25' TRD Pro - Underground
I've gotten a few high beams directed at me especially at intersections. It's not like I have my fogs on too; just my headlights, DRL and fang lights (that doesn't really light up very far, it's mainly used for decoration).
The :devilish: on my shoulder wants me to retaliate and turn ON my light bar too...that'll blind the bejesus outta them. Muhaha-haha. But then the 😇 side would feed into my conscience saying "doing that would surely cause major accidents if everyone on the other side of the street is blinded by the lights". It's no fun being "good" all the time...so I just 🤷‍♂️ it off and let karma deal with em..
ridetime
Oklahoma
I did until I turned the lights down to #2.
This is my setting as well. Use your high beams as a guide to adjust this. Notice that with it on 0 there is hardly any difference in high and low beams which tells me why others flash us. Now try it at 2 and see how much more useful your brights are. 0 and even 1 will get you flashed, especially if you are lifted.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
If I were you, and I'm not so do whatever you like, I'd lower my low beam another 3 or 4 degrees and then use my high beam whenever there were no cars in front of me.
Actually, I think my truck has some sort of smart high beam switch and will do it for me if I want, but I'd rather do it myself.
j.
TheGreatWhiteNorth
TheGreatWhiteNorth
Alaska
2024 SR5
j.
It has a very solid "ceiling" to the projector light where it goes straight black. 3 or 4 is a tad bit too low. Theyre just an ultra concentrated beam.
Texas Bob
Bob
If your truck is stock (no suspension mods, no tire size change, nothing heavy in the bed or on the hitch), and the lights were correctly aimed at the factory, then the light aiming dial belongs at position zero. The numbers on that dial do not represent either inches or degrees, they are just reference points and intended to allow you to dip your headlights when the front of the truck is angled upward due to heavy loads.
My new truck was delivered to me by the dealer with the dial set at around 2 or 3. When I discovered that after a few days, it explained why I'd thought the lights were unbelievably poor considering what we all hear about how much better the LED tech is. I expected the sharp upper cutoff but not the short range, which I felt was dangerous in my often dark, hilly and curvy part of the planet. So position zero is a lot better for me. I do sometimes get flashed by oncoming drivers, but it's not often and I think anyone with decent modern headlights probably gets that sometimes. There is a pretty good video on The Drive about this:
And by the way, the auto-dimming headlight function is useless for me. It is way too slow to turn on the brights and is often fooled by all the floodlights, signs etc. along the road, causing it not to go bright. It is good, though, at turning off the brights quickly when an oncoming car pops over a hill. I think the feature is probably useful for people not engaged enough to turn on their high beams when they could (and likewise too slow or lazy to dim them when they should), because the auto function will never leave them high when they should be low.
