Power tailgate sometimes not opening
andrewleader
Andrew
Washington State
My power tailgate has sometimes been failing to open… it’ll try to open (moves a centimeter), then fails and moves back and makes another sound and then gives up. I have to help force it open to get it to open. It happens about 25% of the time. I’ve had the truck for a year and 23,000 miles.
Anyone else have this issue?
I have the aftermarket rubber tailgate seal installed, I suspect that might be part of the issue, however I’ve had that seal installed for like 15,000 of the 23,000 miles, so it’s not like it’s correlated with that…
The issues started happening after off roading in the Moab area… I thought it was maybe dust related (they have a lot of fine dust there), but even after getting back to the Pacific Northwest, the issue with opening the tailgate has remained and occurs about 25% of the time.
I don't have a tailgate seal, but I can verify that the power tailgates are very sensitive to contacting anything when opening or closing. I am guessing that your seal combined with the Moab dust is the problem and that the dealer won't do a thing as long as the seal is there. Good luck.
Datrane01
Tacoma 2024 Off Road
I have a tonneau cover that touches the tailgate and it started being a problem after a few months. Now it is 100% of the time that I have to put pressure on the tail gate to help it get started opening unless I have to cover not touching the tailgate. It is really annoying. I really wish I could just manually open and close the tailgate.
Appalachian Taco
Damon
Utah
‘24 Taco TRD Off Road
Same issue with bed stiffeners installed. Started happening the more time I spent on trails. I turned off my power tailgate and that seems to help a lot.
Datrane01
I turned off the power tailgate but it did not help the initial lock release. Now just means I have to not only work to force the tailgate to unlock, but I have to fight the servos every time.
andrewleader
andrewleader
Andrew
Washington State
Yeah turning off the power tailgate doesn’t help me either, since it’s just the initial unlatch part (which is always power-based unfortunately).
I’ve also got bed stiffeners but those don’t even contact anything (at least with my brand).
I’m gonna pick up the silicone lubricant tomorrow evening and try that… it feels like it’s dust inside the latches that probably cause it. If that doesn’t work, I’m going to pull off all of my rubber tailgate seal.
Datrane01
Let us know how that goes. I'll probably do the same.
guitarist alec
Alec
california
yep... 25% of the time... I've got a RealTruck Retrax Pro XR retractable Tonneau Cover (which is great) that fits snugly on top of Tailgate so that seems to be the issue 👀 doesn't bother me much but think I'll try that Silicone trick.
andrewleader
andrewleader
Andrew
Washington State
I just put on the silicone spray lubricant and drove 60 more miles and the tailgate opened! My tailgate wasn’t opening 75% of the time lately this weekend, so it seems like it might have helped! I’ll try opening it again over the next few days and report back.
To apply, I opened the tailgate, sprayed the latches on the tailgate on each side, closed it, re-opened it (which it actually opened!), sprayed again, closed again, opened again, and then sprayed again for a third and final time.
It looked really dusty in there with the fine Moab red dust, so I’m hoping that was the issue.
Same issue. Had dealer replace motor under warranty - now it’s doing it again.
andrewleader
andrewleader
Andrew
Washington State
tacorancher, have you been driving on dusty roads? Mine seemed to be related to doing 200 miles of dusty Moab red dust roads…
The silicon spray lubricant has seemed to work, here’s an update…
- 60 miles later, opened fine
- 100 more miles later, opened fine
- Next morning, opened fine again
Yes I’ve only tried that for less than 24 hours, but it’s looking promising!
Lets_Taco_Bout_It
Seattle
2024 Bronze Oxide Trailhunter
I had the same issue. Dealer replaced and straightened the body I think. They said something was bent. it's under warranty so just have them fix it
rchrds
TN, USA
2024 Trailhunter
I'm having the same issues, but I'm pretty sure that its the pressure from my seal on the back door of my camper top, which was always too tight based on poorly sized dimensions. I'll try the lube on the latch and see if it's a combo of the two.
Mine does it with no pressure at all (Diamond back wide open).
