lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I ended up getting a year end 2025 Bronze Oxide Trailhunter with the 5 foot bed. $4000 off TSRP, seemed like a good deal to me. I plan to do this same exact mod to the ARB rack with the Retrax Pro RX tonneau cover. I am hoping my angle grinder skills are up to the task. I am assuming that is the tool of choice for cutting the metal and then grinding it down.
Congrats on your new purchase and bargain!
Got $3474 off invoice in late August for my truck but ugly white.
heavylunch
Wisconsin
2025 Tacoma Bronze Oxide Trailhunter
My daughter really wanted me to get white and nickname the truck "Bone Crusher" but I couldn't do it. I did actually like the white quite a bit. I like the bronze so far but it shows every spec of salt from the Minnesota roads, way more than my old 2019 TRD Pro in VooDoo Blue did. In summer however it will be pretty fun and around here, white trucks in parking lots are everywhere and I grew up with white trucks, had to do something different.
Also, I worked pretty hard on my deal, probably the best I have done, but didn't get quite what I wanted on trade-in. The whole thing is smoke and mirrors once the math is all done. Still, probably the best I have done at the end of the day among the 3 Taco's I have owned in my life.
lauren01
Lauren
Ventura, CA USA
I didn’t do a trade-in on mine. We had two other low value extra cars that we sold, prior to getting the truck, for a total of $13,000.
Hatman
Hatman
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
You are correct. I used a grinder with a wheel for metal cutting, then a grinding wheel to shape it out and finally a wheel for sanding/polishing to make it smooth.
heavylunch
Wisconsin
I started my project today. I got the retrax pro xr on and cut the ARB tabs off. I started to grind them flat but it was taking longer than I expected so I called it good for the day. I still need to get the t slot bolts so I have some time. Should have it done soon. Can't wait.
heavylunch
Wisconsin
It wasn't terrible. But there were plenty of things to mess up if not paying attention.
I ended up using some scrap foam that fit the track width and had a sticky side. Put that in the track and then the ARB on top to position it. Then lifted the foam in the tslot to stick to the metal bottom of the ARB base plate. Then I knew where to drill the holes for using the tslot bolts.
I also had to use a ratchet strap to put tension on the lower portion of the ARB frame to make the part closest to the cab fit the retrax shelf a little better.
Luckily, in this case things went pretty well and it looks great.
Thanks for showing us your method worked!
Hatman
Hatman
Argyle, TX
Anyone try this with another cover, specifically the Bak Revolver X4ts.
That is one of the covers I looked at when I started the project. Other people who have added that tonneau with racks or bars, say it works fine. You just have to roll it up in an oval rather than a round circle, so the rolled cover squishes down under the inward cant of the bars. (go to 3:01 of this video for that example).
These bars were actually my first choice but I opted against them because you have to secure them open with a strap that I thought would be difficult to get to with the sport bar in the way. Maybe if you run. the bars without the molle panel? The bonus to this cover is the T-slot isn't as thick so the bars would sit a slightly lower than the cover I went with.
If you go this route, save the foam off the bottom of the bars when you take them off and reuse it on the area inside the T-slot.
Gonzo
Richard
Ottawa, Canada
Hey Hatman, thanks for the inspiration! Before buying my Trailhunter last Nov I went looking for options for tonneau covers for them and found your post. I finally got mine installed last week! Thanks again…
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_2743
Hatman
Hatman
Argyle, TX
That looks great!! I like the dual channels on the cover. Which one is that?
