- First Name
- Jason
- Joined
- Aug 7, 2024
- Threads
- 0
- Messages
- 304
- Reaction score
- 190
- Location
- Petaluma,CA
- Vehicle(s)
- 2024 Tacoma TRD OR
Thank you for your reply. So likely that just a slight change in driving habits would make the upgrade but with a touch of lag unnoticeable! Will your software be CARB legal with the Stock engine components? Likely not with this turbo upgrade… unless.. as you wrote, this turbo upgrade manufacturer decides to throw some money down for the EOThere is a very small increase in lag with the larger wheels (both compressor and turbine), but it’s subtle enough that most drivers won’t notice it unless they’re specifically trying to evaluate it. In normal or casual driving, the response is effectively indistinguishable from the OE turbo.
Overall responsiveness was a key requirement for this project. When we partnered with TurboKits.com on development, I made it clear that maintaining near-stock transient response was non-negotiable for this particular configuration. TurboKits.com is fully capable of producing more aggressive/higher output, higher-lag combinations, but this setup was intentionally designed to suit the majority of owners who want a meaningful step up in performance without sacrificing drivability.
Regarding CARB EO compliance, that would ultimately be a question for TurboKits.com, as this is their product. That said, the unit uses the factory OE housings, so it remains visually identical to the stock turbocharger.
