4WD Binding/locking
bigrigskitaco
2025 Toyota Tacoma TRD Sport
I'm about to take my Tacoma through it's first big test this weekend. Driving up through Berthoud pass to ski. Wind gusts will be up to 38 mph, the road will be icy, snowy and it will be actively snowing. I have the new Toyota Tacoma TRD Sport. It's my first4WD vehicle so I want to make sure I'm not breaking anything. The pass has switchbacks roads, winding curves, and will be rough as I'll be driving up it around 6am. I want to know if I can leave 4H on the whole time even while taking those sharp turns around the bends without a drivetrain lockup. Any other tips for4WD in these conditions will be greatly appreciated as well.
Note: I have winter tires on and have 210 lbs of sand tied down in the middle of my bed for extra traction
Yotota
SW WA
24 TRD
If you can't see any clear pavement on the road, 4wd will be fine.
If you can see small patches of pavement through the snow, 4wd will still be fine.
If the whole truck is on pavement with no snow or ice, 4wd will bind up the drivetrain. Even on wet pavement, though the unbind skid/scuff will be less noticable than it would on dry pavement. But that's the toughest situation with 4wd because you have to make the call when to switch back to 2wd, when conditions are mixed between blowing snow and dry or damp patches of road.
Keep your driving inputs gentle. Allow lots of following distance. Brake early and smoothly. Snow mode in the truck can help, try it and see how you like it. Make sure your tires are at the right pressure - the main concern is that they aren't too high.
And if possible, find a big empty lot that's covered with snow. Hold your traction control button for a few seconds until everything turns off. Do some donuts in 2wd. It's fun.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
my understanding is it is only bad when taking sharp 90° angles in dry pavement but driving relatively straight under 55mph is perfectly fine for 4x4 on dry pavement.
What you're really gonna wanna pay attention to is the trans temp if your in 4hi.
Now that this is a known "feature" of the these trucks, if it starts getting hot you're gonna want to put it in 4lo.
Just had mine start to climb on me a few weeks ago on a steep gravel uphill that I didn't want to spin on, but didn't really need 4lo either.
Yotota
SW WA
24 TRD
If you're on a dry road, and in 4wd, and you're in a long sweeper corner where you are turning 90°+ over a long distance (like most corners on every mountain pass), it'll still bind up the drivetrain just the same as if you cranked the steering to full lock and turned 90°+.
LincolnSixAlpha
Phoenix
There's one way to answer this... Yup! Dont overthink it. You indicated binding. Yes, that's correct on places like dry pavement, where the tires cannot break free easily. Since you'll be off road, in snow, ice, dirt, etc. that's nothing you need to worry about.
toycoma
tyler
st. louis
2024 toyota tacoma
If you’re going to be in 4wd for a long period of time I recommend putting on tow haul. Had a pretty long trail I took mine on a few months back and I noticed the trans temp starting to rise because of low RPM driving. I put it in tow haul and kept the rpm’s higher than usual and it helped a ton!
as for your 4wd question as long as the roads aren’t completely dry and all pavement your 4wd should do fine. I would take it slow and if you feel anything binding up switch it into 2wd again. Good luck!
I ski a lot and have put at least 10K miles on mine in 4H/4L the only thing to avoid is sharp turns on dry pavement. 4H/4L in Moab tests the drivetrain durability because the rock surfaces are similar to concrete, many necessary sharp turns while in 4H/4L that had the tires squealing, zero problems. No transmission temp issues either. Certainly won’t be trans temp issues at higher speeds and lower temps on a ski trip!
Basically put in 4H and forget about it! Unless the parking lot is clear and dry pavement then put it in 2H but switch while driving in a straight line, or if your stopped with the wheels straight. If you forget you’ll feel the tires binding in the steering wheel, don’t panic just know not to turn as sharp. Not a big deal.
Have a good trip post some good ski pics!
Dirt
Greg
Eastern OR
You'll be fine using the advise above. Just remember the 4x4 helps you move, but does not help you stop. Also, unless the Sport doesn't have it, there's the "manual shift" side of the transmission if you want to hold the rpm's up.
907Yota
Marty
Alaska
1985 Toyota Xtracab 4WD, 1990 4Runner, 2025 4WD Xtracab
It’s one of my dislikes with the GEN four Tacoma. I was in four-wheel-drive because the roads are completely icy where I live in Alaska. As I pulled out of a parking spot at the grocery store and made a fairly normal turn, my wheels ran over a section of pavement that did not have ice on it.
The four-wheel-drive system locked up and made a horrendous pop noise. I was sure I had broke something like TFL did on their video.
A little bit later after cycling between four-wheel-drive and 2 Wheel Dr. a few times the system worked again. The service department at Toyota told me it will pop out of four-wheel-drive to save itself from self-destruction.
I was a little disappointed that a 2 mile an hour turn in a parking lot would be enough to grenade the front end
Luckily, I survived this one. And now I’m careful to take it out of four-wheel-drive whenever possible if it’s not absolutely icy or snowy.
trailhunger
2024 TH
That’s pretty cool it’ll do that.
My TH shifts into 4H quietly but kinda loud shifting back to 2WD. Unless I slow way down or come to a stop even then can feel the disconnect isn’t buttery smooth
bigrigskitaco
Thank you all for the help. Without response I would’ve been dead in water but I confidently switched from 2H to 4H. Cornered turns, hit switchbacks and tackled the harsh snow and winter conditions that had multiple cars in snow. Everything went great except my new winter tire blew up in Broomfield :/ Oh well
2024 Tacoma 4WD Binding/locking 16FC8BD7-3016-491F-94AC-1DD7959EC1E2
2024 Tacoma 4WD Binding/locking IMG_2103
Yotota
SW WA
24 TRD
Sucky about the tire, but glad the truck performed well!
