fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
I know there are plenty of YouTube videoed on this, but here’s what to expect for the install of the ECGS diff carrier bushing on my 2024 SR5. If you aren’t familiar, all the 4wd Tacomas from second gen (something like that.. feel free to correct me) onward use an idler needle bearing to support the CV on the drivers side. When the truck isn’t in 4wd, the cv turns against this needle bearing and when the front is raised at all, to where the CVs are at any downward pitch, you will feel a vibration at street and highway speeds through the steering wheel due to the side loading on the not so tight tolerance between the shaft and bearing. Here’s the step by step of it.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1188
Separate tie rod end.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1155
Remove lower mounting bolts holding lower ball joint assembly to spindle.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1157
Remove dust cap from hub.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1158
Remove CV nut using 35mm socket, then separate CV from spindle
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1159
Prop or tie the spindle out of the way and be mindful of the brake lines/speed sensors wire.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1160
Pry the cv out, be careful of the dust shields but these can be straightened if bent.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1161
Despite the loud vibration, the shaft surface against the needle bearing is in great shape.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1190
Insert paper towel or plastic bag into splines to prevent extracting tool from falling into diff.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1189
Set slotted nut from extractor tool in behind needle bearing(I had to slightly bevel the edge to get it in easily.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1187
After popping the oil seal out, thread in the all-thread and plate making sure the slotted nut is seated only against the needle bearing and pull it out. You will run out of length and need to put supportive backing between the plate and the diff to get it all the way out.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1168
No damage found on my needle bearing thankfully despite the intensity of the vibration.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1182
Using the driver, take your time lining up the bushing and pound it in. The driver will bottom out when it is flush.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1192
The bushing should look like this when correctly seated.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1183
Install new oil seal.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1184
Line up splines and pound shaft back in until it’s all the way in!
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1185
Putting everything back together is just a reverse of the Teardown, but I like to add anti seize when appropriate. Be sure to either top off or replace the diff fluid before putting the wheel back on.
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1175
With the installation complete, the vibration has completely disappeared. I consider this supporting mod to be non negotiable with any height adjustments to the front of the truck no matter how slight.
https://eastcoastgearsupply.com/c-1025774-toyota-clamshell-bushings.html?facet-categories=1025774
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) IMG_1096
gofastdan
Nice write up! Just to be clear, the website doesn't list a separate kit for the '24+ Tacoma. Did you use the kit designed for 2016 and newer Tacomas?
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Wow, thank you for an amazing ride u, and visuals.
? What are the ECGS bushing and how do they work in comparison to the stock needle?Bearings.
I have a king lift on my truck and im not experiencing any vibrations at the moment, but would like to avoid any in the future. Any help would be appreciated.
Nice looking truck
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) 20251130_134417
Toyotimothy
Timothy
Selmer, TN
Just bought mine. I have a 2” spring lift and haven’t experienced any issues yet but I don’t want to either. Great write up and thank you for sharing. Do you know what type of diff fluid is recommended for the Tacomas and how much. This will be my first time doing a diff refill or change. Thanks again
fzjeddie
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
Good question and you would be correct. The only difference from the third to fourth gen’s as it pertains to this job would be the oil seal. They sell the fourth gen seal but not a seal driver for it, but it goes in very easily.
fzjeddie
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
I’ve heard of some people not having immediate issues and others like me who had an instant vibration. I used 75/90 valvine gear oil to top it off.
fzjeddie
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
Nice looking truck
Very nice! I have roughly 2” in the front and had noise immediately, though I’ve heard of plenty of guys who haven’t immediately. Basically, when the truck is in 2wd, the cv idles against the bearing in the stationary carrier as support when the diff isn’t engaged. When you’re in 4wd and the diff is engaged, they have the same relative motion and no vibration is made. Because the tolerance isn’t super fine, and it’s to allow the splines some play, the needle bearing becomes side loaded with even the slightest height adjustment. The bushing is a direct replacement of the bearing dimensionally, but eliminate the moving parts that cause the issue.
Toyotimothy
Timothy
Selmer, TN
You’d think Toyota would have fixed this by now. Seems like a simple fix. I guess they have the mindset of if it ain’t broke don’t fix it but with individuals lifting these trucks even a little bit they should know what it’s going to do. I wonder if they replace anything when they do a factory lift. Or if they leave it to vibrate.
fzjeddie
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
I also found that interesting. Not a problem on stock height but Toyota knows that half the Tacomas they sell will get lifted at some point. I’d be very interested to know what the factory lifted ones have done if anything.
Drifte
Colton
Iowa
24 Tacoma, 20 RAV4, 10 Tundra, 99 C5
Very interesting. I had to replace the bearing with that bushing in my Tundra at 180k miles. I have the All Dogs lift on my truck now thats about a 1-1.5" lift in the front and immediately notices a hum that transfers through the chassis as nvh. I wonder if its this bearing or a driveshaft/pinion angle problem. Thanks for posting.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Approx how much would you save doing this work yourself? I'm still new to mods/maintenance. This will be my first time doing something this....advanced?
JuanitoBonito
Juan
Chi-town
On that note, MY TRD 2&1/2” Bilstien lift has extended axels. Would this resolve the impending issue?
fzjeddie
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
The cost for a shop to do it would be a very good question… maybe someone on here could help answer that better than me. My best guess is that it would be between 300 and 500 in labor. It took me 2 hours to do. All opinions are relative, professionally im a machinery mechanic, but having wrenched on Toyotas for about a decade, I’d consider this job to be on the lower end of intermediate.
Anthony
Aberdeen Wa
Thank you for explaining what you accomplished and why, something to look into. If you don't mind, how much did it cost in part? And did you have to get an alignment after you installed them.
