btrdz
B
2026 TRD Off Road
I know there are plenty of YouTube videoed on this, but here’s what to expect for the install of the ECGS diff carrier bushing on my 2024 SR5. If you aren’t familiar, all the 4wd Tacomas from second gen (something like that.. feel free to correct me) onward use an idler needle bearing to support the CV on the drivers side. When the truck isn’t in 4wd, the cv turns against this needle bearing and when the front is raised at all, to where the CVs are at any downward pitch, you will feel a vibration at street and highway speeds through the steering wheel due to the side loading on the not so tight tolerance between the shaft and bearing. Here’s the step by step of it.
Separate tie rod end.
Remove lower mounting bolts holding lower ball joint assembly to spindle.
Remove dust cap from hub.
Remove CV nut using 35mm socket, then separate CV from spindle
Prop or tie the spindle out of the way and be mindful of the brake lines/speed sensors wire.
Pry the cv out, be careful of the dust shields but these can be straightened if bent.
Despite the loud vibration, the shaft surface against the needle bearing is in great shape.
Insert paper towel or plastic bag into splines to prevent extracting tool from falling into diff.
Set slotted nut from extractor tool in behind needle bearing(I had to slightly bevel the edge to get it in easily.
After popping the oil seal out, thread in the all-thread and plate making sure the slotted nut is seated only against the needle bearing and pull it out. You will run out of length and need to put supportive backing between the plate and the diff to get it all the way out.
No damage found on my needle bearing thankfully despite the intensity of the vibration.
Using the driver, take your time lining up the bushing and pound it in. The driver will bottom out when it is flush.
The bushing should look like this when correctly seated.
Install new oil seal.
Line up splines and pound shaft back in until it’s all the way in!
Putting everything back together is just a reverse of the Teardown, but I like to add anti seize when appropriate. Be sure to either top off or replace the diff fluid before putting the wheel back on.
With the installation complete, the vibration has completely disappeared. I consider this supporting mod to be non negotiable with any height adjustments to the front of the truck no matter how slight.
https://eastcoastgearsupply.com/c-1025774-toyota-clamshell-bushings.html?facet-categories=1025774
Hey just wondering about your roof racks.. I carry my canoe often and will be look for some cross bars like yours, what brand are those? Thanks.
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Thank you for explaining what you accomplished and why, something to look into. If you don't mind, how much did it cost in part? And did you have to get an alignment after you installed them.
No alignment necessary as long as you don’t loosen the lower control arm bolts, I wanna say it was just under $200 for the bushing, driver, seal and extractor tool.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
? What what what, an improvement on our trucks for 2 c notes unheard of lol
Why the hell didn't toyota do it in the first place, oh, I know because they want them to break and for us, to have them fix it.
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
I think it was more like $170, nevertheless, this is only necessary when the front is lifted at all. What id like to know is how the factory lifted trucks are faring or if anything about the needle bearing is done on these trucks. Mine is lifted less than the factory trucks and still was loud immediately. Altogether, I think its nice that the bushing is a case closed fix and doesn’t open up a list of new variables in need of correction.
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
I have Yakima 60” wings and mounts on the cab and ordered the leer topper with the Thule crossbar option. I requested 60” but they gave me 48” and I was too lazy to do anything about it in time.
btrdz
B
2026 TRD Off Road
Thanks! We u-bolted some 2x2's on my buddies 3rd gen Tacoma to carry 2 canoes last summer, I was never confident doing that with my Jeep due to the mounting on the drip rail setup. Our canoes are 34 inches wide each, should be good to get both on 60 inches with a staggered position.
Approx how much would you save doing this work yourself? I'm still new to mods/maintenance. This will be my first time doing something this....advanced?
A good mechanic should be able to do this in under 2hrs. Not sure about book time? Depending on shop rate about $300?
Anthony
Aberdeen Wa
Factory is either jamming up the suspension with pucks, or they're putting on their mild ready lift or going with there pro options?
My Kings suspension with the new total chaos UCA , was installed by my Toyota dealership . They installed it, but were leery to adjust the front due to the dreaded vibration caused by lifting it and putting in a differential drop.
Never once did they tell me about a bushing that could fix it all, imagine that.
828findadventure
Eric
North Carolina
2025 Toyota Tacoma SR5, 2021 Toyota Tundra SR5
Great pics and breakdown. I experienced this needle bearing vibration at 30-35 mph on our 3rd gen Tacoma OR with a 2" Toytec top spacer lift. We now have a 25 Tacoma SR5 and a 25 4Runner SR5. I haven't noticed an issue in 5000 miles with the Westcott 2.5" preload collar lift and OE springs. It changes everything. BUT, lift a 4th gen Tacoma or 6th gen 4Runner 3" or more, and I have read, there will be an issue.
Lifted my 4th gen 1.5 inches, got the vibration. ECGS was the fix.
BBoyM3
Robert
San Antonio, TX
2015 Toyota Corolla LE / 2025 Toyota Tacoma TRD Off Road
I have 2025 OR with the Readylift SST 2.1. For those who have installed the ECGS bushing kit on a 4th Gen, do you get a slight rhythmic vibration over 35 mph? It’s not drastic, but I can feel it in the steering wheel. Is this normal after the bushing install? Forgot to mention the vibration is lessened when I put it in 4WD (similar to when I had the needle bearing).
Anthony
Aberdeen Wa
Not supposed to? That's what it's supposed to fix. I have a 3" King lift on my 24 TRD off-road that Toyota installed and at 16k I haven't experienced the vibration at all, but have the ECGS too install. Make me wonder what other installers are or aren't doing right 🤔
Anthony
Aberdeen Wa
2024 Tacoma East Coast Gear Supply diff bushing DIY install (step by step how-to) 20260116_163053
