Nvideon
Boynton Beach FL
I just went ahead and installed the headlights with the drl harness. Tapped into the Horn and Eng 2 IGR.
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062605
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Can you give us some details on it’s behaviors of the DRL?
right now without the harness hooked up my drl dances when I unlock only with ambient light is low or night time. It does not dance in broad daylight and it does not activate when locking.
Does yours dance in midday sunlight when unlocking and locking?
Nvideon
Boynton Beach FL
Activation sequence works for me when locking and unlocking. Complete darkness, with some light, and daylight. Worked every time.
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
2025 Toyota Tacoma TDR Pro
Ok, that’s pretty rad. Now I’m considering adding the harness in. Was that part difficult? Do you feels it’s manageable with the grill back on? I do not feel like taking that thing off again.
Nvideon
Boynton Beach FL
You should easily be able to add the harness with the grill/bumper on.
The only things youll most likely have to remove are the intake piece and radiator cover. The ones held by flush push lock clips.
I also made small cutout for the fuse taps.
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062645
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062647
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062648
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062649
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 1000062650
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
So as I expected.
With DRL harness - light sequence unlock, lock, full daylight and night.
Without the DRL harness - light sequence unlocking only and at low ambient or night time only.
is it just me or does Alpharex need to update their instructions.
Nvideon
Boynton Beach FL
So as I expected.
They for sure need to update/add. Update so that both non-hybrid and hybrid are covered. Maybe a more indepth video too
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
I sent their tech support an email on Dec 4th. 10 days later nothing from them except some customer service person saying they will let tech support know and I should get information soon.
VB Taco
Virginia Beach, Virginia
Don't hold your breath.
I let them know of some incorrectly written instructions and was told they would fix it.
Didn't get that reassuring feeling that they really cared.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Pretty disappointing. Maybe they don’t feel like they need to try and please their customer base because they have plenty to support their business.
The Sasquatch
CT
TBD
dumb question from the non-electrical people …. Does the harness come with those “taps” and you just plug them into an empty fuse or how does that work? Do you need to do some basic wiring for the connector piece?
VB Taco
Not a dumb question all.
The "tap" should come with the harness. Remove the designated existing fuse from the fuse box and install it next to the new fuse that is supplied in the "tap".
Install the "tap" back in the same spot that you originally took the fuse from and you are done.
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 20251229_101457
2024 Tacoma AlphaRex Headlights and Tail Lights Installed - TRD Pro 20251229_101539
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Which fuse did you tap into in this photo? Looks like towing igr which is 7.5 amp. Did you have to use the same amperage fuse or can you use lower amperage?
Also what are you powering with the 7.5 amp fuse tap?
