TRD Pro wheels & tires setup on TRD Sport?
Zigity
Connecticut
2025 Tacoma TRD Sport DCLB
First truck, so I’m a noob when it comes to truck wheels and tires. Most of my experience in this field was installing coilovers, sway bars, and adjustable endlinks on (and lowering) my 2003 Mazdaspeed Protege, hah.
I hate the chrome accent on the TRD Sport rims. I want to get the factory TRD Pro rims for my Sport. I think I found the part number after searching another thread. They’re 18” rims and should fit fine. I will not be doing any suspension or lift mods.
PT946-35240-2F - TRD Pro 18” rims
PT998-89210-F2 - Centercap (can I reuse the Sport rims centercap?)
My main question, aside from confirming the part numbers, is about tires. What type of tires come stock with the Pro? I’m guessing it’s A/T tires, whereas the Sport likely has street tires? I think those rims would look off with street tires, but I want to maintain as much MPG as possible while still rocking A/T tires (I live in New England, so I think they could help in winter, too). What size tire should I be looking at with those rims on stock suspension? I know the Pro has a slight factory lift, and I’m not sure if that impacts tire size for the Sport.
Compherh
Sam
Miami
2025 tacoma limited hybrid
First truck, so I’m a noob when it comes to truck wheels and tires. Most of my experience in this field was installing coilivers on and slamming my 2003 Mazdaspeed Protege, hah.
The sport offroad and limited are about the same height. I have limited using bridgestone dueler at 275/70 R18. Lost 3 mpg from stock on highway. I also have wider rims fuel rebel 18x9 +25 offset. Stock no rubbing. Rims were about 400 a piece. You can get oem used trd rims much less.
Zigity
Connecticut
Thanks for the info! Do you think putting a stock TRD Pro setup on the Sport (same tires as the user posted previously) would sacrifice any MPG? And are those tires good for snow?
Zigity
Connecticut
Since these will be daily driver tires on 95% paved roads, and I live in New England (rain and snow), I’m thinking the Wildpeak AT3 tires would be my best bet to pair with the 18” TRD Pro rims.
Compared to other options, such as K02s, my research has told me that the Wildleak AT3s are quieter on road, perform better on wet roads and in snow, and are lighter weight. All three of these things are a win for my typical use of the truck. Anybody care to comment on my take here? It’s a lot of info to dissect!
Compherh
Sam
Miami
Rolling Resistance:
The wider the tire and the tread compound determines the resistance of the tire to roll. A highway tire (stock on sport) and an AT tire do not roll the same. AT tires and mud tires don't roll as smooth. They are designed to grip on gravel/mud. I had K02 on my F150 and they are a hard rubber and made a little hum at 45. Goes away at 70. Supposedly the K03 are better.
Unsprung Weight:
This is the weight at the wheel hub. The weight that needs to be moved to get the wheel turning. More weight = less mileage. You can google wheel and tire weight from stock to new setup and see the difference. 50 pounds extra in the chair is nothing compared to 15 pounds at the wheel hub. I went with bridgestone vs bf goodrich because they weigh less for same size.
Mini2nut
Falcon Wildpeak tires are notoriously heavy.
Tacohunter2024
Upstate New York
'24 Off-Road Premium Black
I have a 2024 Tacoma Off Road. I was about to order the same wheels, wondering they went on your Sport fine? Did you have to change lug-nuts or get spacers? I', getting the Falken AT4Ws, I'll get the same size as the TRD Pro 265/70/R18, just concerned if everything latches up OK/if it worked out for you?
Zigity
Connecticut
I still have my factory 18” Sport rims.
Changed tires to 265/70R18 Toyo AT3’s (SL rated).
Everything mounted fine, and I have all factory/stock suspension.
After considering the paint chip potential, I’m leaning towards the TRD upgrade rims over the Pro rims due to offset. For context, here are the two part numbers of the “Upgrade / Pro” rims I’m referring to:
TRD Pro 18” Rims: PT946-35240-2F
TRD upgrade Rims: PTR56-35242-F1
2024 Tacoma TRD Pro wheels & tires setup on TRD Sport? IMG_9502
Tacohunter2024
Upstate New York
Thank you for replying, to be honest I wasn't completely aware of the paint chip issue. The upgrade wheels look like a potential solution, but they're about $80 more expensive at the dealers around me, plus I kind of like the look of the Pro offset.
You've given me a reason to take a breath and think this through a little better. I do notice little scratches and chips on this paint already, I don't want to add to it.
Deleted User 412290
Check out the SL Yokohama Geolandar A/T4 in 265/70R18. Light and not too aggressive. J have them in 275 and like them a lot. All AT tires will have a little more road noise. But something like the Dueller AT we had on my wife's wrangler was fairly quiet.
For the wheels you can find a dealer that accepts the one time "GR owners" 25% off code and stack that. I got my OEM trailhunter wheels with center caps for $870 after tax
I personally like the little bit of poke from the offset and I don't lose sleep over the potential of rock chips. Is what it is, I'm not rich enough to PPF my sr5
Tacohunter2024
Upstate New York
I have the 4 TRD Po wheels and centercaps in my cart for $984 after tax. Dealer is close-ish. I'm kicking myself because they had an additional 15% off up until New Years. Thank you for the code, it doesn't look like they accept it but it was worth a shot.
Did you use the same lugnuts from your stock SR5 wheels?
I think you're right, I hated these OR wheels before I bought the truck, but got the Off-Road because I didnt like driving with the Sport hood scoop, and the Sport doesn't have crawl control, OR even has a better camera system...I can change wheels, pretty hard to add crawl control. So this was always the plan, I just got cheap.
****Edit I kept searching and found another GR related code. Down to $738 now, I'm doing it. Thanks man, you just saved me $250
Deleted User 412290
Check some dealers within an hour or so! When I got my wheels I founder a dealer 45 min from me that accepted it and picked up.
Yep, same lugs. Everything is the same +20mm offset is the only difference.
2024 Tacoma TRD Pro wheels & tires setup on TRD Sport? PXL_20251230_190450257
2024 Tacoma TRD Pro wheels & tires setup on TRD Sport? PXL_20260104_220427363.MP
2024 Tacoma TRD Pro wheels & tires setup on TRD Sport? PXL_20260104_220630591
