- First Name
- Quez
- Joined
- Sep 25, 2024
- Threads
- 19
- Messages
- 156
- Reaction score
- 260
- Location
- Nashville
- Website
- www.bigdawgstoyotatuning.com
- Vehicle(s)
- 2025 TRD Pro, 2025 TRD Pro 4Runner
What’s going on everyone!
I wanted to share some details and first impressions on an upgraded replacement OEM turbo from bigdawgstoyotatuningshop.com that I’m installing on my 4th gen Tacoma as part of prepping for a Stage 3 tune from OTT.
Turbo Upgrade for the 4th Gen Tacoma
This turbo is still OEM-based, so fitment remains factory-correct, but the quality difference is immediately apparent. The overall construction feels extremely stout and well-built, and it’s far more confidence-inspiring than the stock unit. Just holding it, you can tell it’s designed to support higher boost levels and sustained power without compromising reliability. It honestly feels great in hand and like a proper upgrade for anyone looking to push the platform further.
If you’re planning to do this swap, definitely don’t overlook the smaller install details when ordering parts. New gaskets are a must. I reached out to OTT directly and they provided a breakdown of what’s required, what’s recommended, and what’s optional. I decided to get the parts so I can replace everything while I'm in there. My mindset is that it’s cheap insurance and helps prevent leaks or issues once everything is buttoned back up. All the supporting parts (aside from the turbo itself) came from my local dealer, and I was into everything for under $300.
When it comes to tuning, this turbo really makes the most sense when paired with OTT. They were involved in helping develop this upgrade, so sticking with their calibration felt like the obvious choice. OTT is clearly at the forefront of Toyota tuning right now and, more importantly, they are the only certified Toyota tuner. That certification carries weight here — not just from a performance standpoint, but also for long-term reliability, safety, and proper ECU calibration on these newer platforms. Their Stage 3 tune is designed around supporting hardware like this upgraded turbo, which is why the combination works so well. I also really like that they offer their calibrations across multiple platforms: VF Tuner, HP Tuners, and now even as Cobb Pro Tuners. Truly hard to beat.
Overall, if you’re planning a Stage 3 build on a 4th gen Tacoma, this upgraded OEM turbo feels like an excellent foundation. Factory-level fitment, noticeably stronger construction, and a setup that works seamlessly with OTT’s tuning philosophy.
Happy to answer any questions and I’ll be sure to update once everything is installed and tuned.
