fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
I finally tied it all together with the tires. Was stuck between 33s and 35s, ended up pulling the trigger on the 285/75/17s.
Suspension wise, the truck has Bilstein 5100 shocks with the snap ring on the middle slot, which I wanna say is right at or under 2” in the front. The rear has a 1” spacer, but I’m also using my air lift bags to help it about an inch or so due to the 220lb topper.
I haven’t yet stretched her out, but no rubbing during normal driving.
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) 43110-48e26d0ef3dea31248853865f8239915
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) IMG_1773
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) 43112-43d9b5cda28ac52551db4f21fe6e3f9d
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) 43113-67a107f3117df2eba55adb55d8a5e85a
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) 43114-699a2cf9a99f3a029f1ff9bcee1be141
PNWkip
2025 DCLB SR5
Looks really awesome.
I just did the 5100s yesterday. @ the second setting (1.4") I'm perfectly level with no weight in the bed and a full tank which is odd because I've seen folks online say they're perfectly level at 1", 1.4", 1.8", and 2.1".
Anyways, great rig ! And thanks for the previous write up about your needle bearing. Have that saved.
Was removal of crash pad necessary or did you just adjust the suspension
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Did not have to remove any of that. Front is set at about 2” higher than stock, but that was done before the tires were added. I’ll have to see if it rubs next time I take her out for a stretch.
JuanitoBonito
Juan
Chi-town
Looks great Eddie! Color really pops in the AZ sun .
Gearman
Kris
Utah
2019 F350 Platnum, 2025 Tacoma OffRoad Premium
Looks good, do you have a photo straight on? to see width.
Are those stock wheels? Wondering about wheel offset, compaired to my TRD wheels on my OR.
Want to understand what you did for lift, just shocks, no springs?!?! I am confused, sorry
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Middle slot of front shock is what the ride height is set at. In the back I only have spacers and air lift bags. Wheels are factory sr5 wheels.
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) IMG_1817
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) IMG_0952
2024 Tacoma 285/75/17 BFG KM3 installed (on Bilstein 5100 shocks) IMG_1814
Gearman
Kris
Utah
Thanks, looks great with those tires! Will do some more research on wheel specs between the SR5 and TRD OR. I would think they are similar offset and width..... but who knows.
fzjeddie
fzjeddie
Eddie
Phoenix, AZ
2024 Tacoma SR5 4x4
Might want to verify this to be sure, but I believe the sr5 17” wheels are a +55 offset and the TRD 18” wheels are +20
PNWkip
2025 DCLB SR5
Not 100% sure, but SR5 might be +60? Didn't look too hard for those but:
+55 OR
+20 Pro/Trailhunter
