2025 Tacoma SR5 skid plate options?
Danielc
Daniel
Lakewood, Colorado
2025 Toyota Tacoma SR5
So I bought the Rough Country skid plate for my truck, and after wrestling with it trying to get it in without a lift, I decided that I made a bad decision. I see other plates that are aluminum, one piece, and they have two elongated bolt holes to hold the plate up while you start the rest of the bolts.
Has anyone had good luck with this style of skid plate, and if so can you link me to the one you have? I even saw somewhere that there are SR5 labeled 4runner skid plates that will bolt onto my Tacoma.
I'm open to any feedback. Thanks in advance!
I have the OEM TRD (aluminum) plate on mine. Like you said, it has the two elongated holes so that you can sit the plate on those and take out the other 4 bolts and just slide it off. Super easy to do by yourself too.
Danielc
Danielc
Daniel
Lakewood, Colorado
Thank you! Do I need to pick up that additional crossmember to get it to fit on my SR5?
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
I went online and found it on sale at Elmhurst Toyota 3-1/2 miles down the road from where I was going. Saved $86.50 off the retail price and it would have been $73 to have it shipped. So I saved that since I picked it up. Had to enter my family’s Illinois address to be able to do a local pickup on the website.
I had already added the RCI cross member on my truck and had switched out the fiber skid plate for the plastic “Off road” skid plates.
Danielc
Danielc
Daniel
Lakewood, Colorado
Thank you, and the crossmember is required for it to fit a 2025 SR5?
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Agree, you will need to buy the cross member. I have 1/4" aluminum full skids underneath mine and access to everything is easy. Installing was simple due to the rear of the skid plate hangs off of the two bolts, while you put the bolts into the cross member.
To make oil changes easier I installed a fumoto valve.
Very Functional and would recommend.
TX-MD
marvin
AR
Tacoma, 4Runner
+1 for the “TOYOTA”/LC skid. Super easy to install and you will require the additional crossmember being a SR5. Plenty of access at my stock height and the wide holes def made it easier. I added the OEM front recovery points while I was at it.
Now I just need it to warm up so I plug the holes on the control arms…..I finally heard the whistle everyone talks about.
Anthony
Aberdeen Wa
Interesting, i didn't here awhistle out of my upper control arms.But then again, I replaced them within a thousand miles with Total Chaos with a king lift.
TX-MD
marvin
AR
Tacoma, 4Runner
It’s apparently very common with the “poverty” edition when taking off the air dam. Looking at your truck, you likely aren’t in that class.
Deleted User 412290
Middle class $37K truck guy here 🖐 Can confirm. Immediate whistle on my SR5. Fixed with some $5 plugs from Amazon
jsuber
juke
Jls297#40601
Millercat makes a great product.
