Hybrid and a Winch?
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
After seeing the numerous posts about the anemic 4th gen 12v system on the hybrid models, has any of used a winch for a real world recovery?
I'm interested in knowing if there's enough juice to run one before I pull the trigger on a 10K?
jmw451
Cary, NC
Hey! I have a 25 Pro with a 10k winch hooked up to an SDHQ power relocation kit. Used the winch last week to pull out my coworkers work truck. It worked flawlessly! Hope that helps
2024 Tacoma Hybrid and a Winch? IMG_4339
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Yes Sir, thank you! Any after affects on your 12v battery?
I normally swap in a bigger AGM battery on previous vehicles when I add a winch. Great news that the Pro is handling it. Does yours have the alternator?
myhikingboots
Chuck
Atlanta, GA
2025 Tacoma Trailhunter
I have a 12k winch on my TH but I haven’t had to do a recovery yet. I did pull the truck with light brake pressure to tension the synthetic line onto the reel with zero problems. Where did you get this information about an anemic 12v system?
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
I got the anemic part from everyone who has reported on this forum their batteries dying after sitting just a couple of days and having to jump start with a jump box.
myhikingboots
Chuck
Atlanta, GA
I’ve had my truck for almost a year now and I have never had a problem with it starting although it’s rare that it sits more than a couple of days. FYI I wired the winch directly to the battery with 20’ of 2 awg cable with a solenoid interrupt, wired to one of the auxiliary switches. Good luck with your installation and I would be happy to answer any questions.
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Thanks, I'll give you a holler when i get there.
shackley
www.swxrflab.net
So this relocation just runs from the battery in the back, and I assume you can 1) connect the winch to it, and 2) charge the battery. Correct? Did you buy their cables, or others? There are cheaper options unless they require their cables.
jmw451
Cary, NC
Yessir! It runs to the standard starter battery under the back seat. You can connect whatever accessories you have to the terminals that are mounted under the hood.
jmw451
Cary, NC
So far no negative effects. I run the winch with the truck on but run my fridge off of an outlet i installed in the bed. It’ll run for a couple hours before my fridges auto voltage drop meter turns itself off.
I’m not sure if I have an alternator tbh. I’ve never paid attention to it lol.
shackley
www.swxrflab.net
A bit expensive, but pretty cool. It looks like you have to buy it in three parts, cables, and the other parts for the engine compartment. Is that correct, and do you have a link? Sorry for so many questions, but I plan on a winch and I'm getting tired of raising the seat to charge the battery.
jmw451
Cary, NC
It definitely wasn’t cheap but well worth it for what I have planned for the truck. Ifigured it was a buy once, cry once kinda thing. It’s been one of the best mods I’ve done as far as future proofing the truck.
You don’t have to buy it in parts. They sell it as a whole kit already put the together. It took me a couple hours to install in my driveway. Victory 4x4 sells something similar as well but looked a little cheap imo.
https://sdhqoffroad.com/products/24...v6oLAz3xPEoHN0WOZh5cIPKuVJTV0yypfOlq7b_ZuHvyw
shackley
www.swxrflab.net
Thanks again.
