- First Name
- Dave
- Joined
- Jun 9, 2024
- Threads
- 21
- Messages
- 527
- Reaction score
- 659
- Location
- Los Angeles
- Vehicle(s)
- 2024 Toyota Tacoma 4x4 Long Bed
earnin stripes 🫠
earnin stripes 🫠
Pretend this is all caps: your truck looks amazing!![]()
First 4th gen on Bilstein 6112s! Ride is so good.
Screwed around with visor MOLLE to rearrange gadgetry. We had a set of 1’ Rollercam straps gathering dust. These straps are designed for use with MOLLE panels. They are a nice fit on the small BulletPoint visor panels.
On driver’s side, I attached a Gerber multitool. It’s heavy but seems secure up there. On passenger, I put the other Rollercam for wifey use. Then a hat clip that she picked up, a cheapie 3D print. It was chill to screw around with these fun little panels.
The visor MOLLEs are from BuiltRight Industries. They are aluminum and really nice.Did you also remove those ugly ass visor stickers? What brand are the panels you went with?
Yours looks a lot tighter to the recovery hook than mine ended up, yours looks like its making contact with the raised lettering and should either be spaced out or warrantiedFinally got the SXTH bed step relocation bracket installed, so my ARB right side recovery point is back on the truck. Fitment barely clears.
It works so far. Yay…been months til we got around to this. My gratitude to wifey for breaking the bolts free while my wrist sprain heals. I did the bracket swap, then we teamed up to bolt the bed step/SXTH and ARB back on.
On the picture with the bed step down, I think I see what you mean in the back… will take a clearer pic and ask SXTH about it. Can’t have that thing rubbing. Thanks for noticing.Yours looks a lot tighter to the recovery hook than mine ended up, yours looks like its making contact with the raised lettering and should either be spaced out or warrantied
I plan to throw on a viofo or something in the next month and was looking at the dongar adapters after, unironically Chloe's video as well. I noticed their Pro+ is on preorder for may. Do you utilize any of the parking options and how do they work? No worries if not, i'm not that concerned about parking options, i'd be fine with it just recording while the ignition is on.Previously I put in the Dongar Pro power adapter. Works as advertised. Hat tip to Chloe Kuo (YouTuber/Toyota Ambassador) for clueing me in.
It is plugged into the auto dimming mirror, under the shroud on the upper left.I plan to throw on a viofo or something in the next month and was looking at the dongar adapters after, unironically Chloe's video as well. I noticed their Pro+ is on preorder for may. Do you utilize any of the parking options and how do they work? No worries if not, i'm not that concerned about parking options, i'd be fine with it just recording while the ignition is on.
Also, did you plug into the auto diming rearview power or into the headliner console dashcam power? Just trying to figure it out and proper cable routing. Not sure if i need a rear or cabin fisheye either.
I think that’s normal. It looks like it “could” rub against the tow hooks but it’s actually 1/8-1/4”cm apart.On the picture with the bed step down, I think I see what you mean in the back… will take a clearer pic and ask SXTH about it. Can’t have that thing rubbing. Thanks for noticing.
Mine is rubbing and scraping. I pulled it down by hand with my face close up. :/I think that’s normal. It looks like it “could” rub against the tow hooks but it’s actually 1/8-1/4”cm apart.
Also installed a pair of Trumgeta rubber stopper covers…so bugs and rats don’t crawl up in there.
