Just installed the rear dome light for 2024+ Tacoma
Lexland_Official
Devin
Tacoma TRD Sport
Do you feel the Tacoma interior is too dark?We had installed the rear dome lights on the 2024+ Tacoma,let's see how it looks!
  • High-Brightness LED: Provides bright, even lighting for clear visibility inside the vehicle, even in low-light conditions.
  • Dual-Color Modes: Easily switch between red and white lighting to fit different driving or camping needs.
  • Plug-and-Play Installation: No wiring modifications or special tools required. Quick and easy DIY installation for Tacoma/4Runner owners.
  • Durable Build: Made from high-quality ABS material with heat-resistant and shockproof performance for long-lasting reliability.
  • Modern Design: Sleek style matches the Tacoma/4Runner interior while delivering soft, comfortable, non-glare lighting.
20% Coupon Code: Tacoma4G
Tacoma Rear Dome Light👇
https://lexland.com/mil0ho
Light up your Tacoma interiorđź’ˇ
đź’ˇ
tacomasport1121
Robert
2024 Tacoma Sport
It’s amazing how much more light this LED puts out!
FinallyErik
IL
2024 SR5 DCSB 4x4
Bought and installed one of these weeks ago. Took longer than it should’ve though because it was mis-wired from the factory. Luckily I didn’t have to solder anything
Stingertron
2026 Tacoma TRD OR
How was yours miswired or how was it acting? I ordered this as well and it doesn't seem to function as intended.
FinallyErik
IL
2024 SR5 DCSB 4x4
on the end that plugs into the vehicle I just started switching wires. You can very very carefully bend the tabs and remove each wire from the white plastic part just be super careful.
When I first installed it, it would not go on/off with the doors, only when you pressed a button. So I had to mess with a few of the wires and keep testing combos till it worked. Definitely frustrating, I’m glad I didn’t break any of the tiny silver tabs for the wires.
FinallyErik
IL
2024 SR5 DCSB 4x4
đź’ˇ
FYI it seems your latest batch isn’t wired properly which is causing issues when installed.
28Gauge
2026 Toyota Tacoma Off Road Premium
I really hope that this isn't the case. I just ordered one these.
FinallyErik
IL
2024 SR5 DCSB 4x4
I really hope that this isn't case. I just ordered one these.
It’s not a huge deal, just gotta switch up a few wires if it’s not working properly. Just a pain in the balls more than anything.
FYI the Meso appears to be the exact same product with a brand name markup. If that’s the case it’s possible their wiring could be jacked up as well. YMMV
Orrrrr, the Lexland is a cheap Chinese knockoff with their wiring jacked up.
FinallyErik
IL
2024 SR5 DCSB 4x4
It seems unlikely this niche product is being made by more than one supplier. They’re both cheap Chinese. One has a brand markup
Lando
This would anger me and drive me nuts!
tacomasport1121
Robert
2024 Tacoma Sport
Would you by chance happen to be able to snap a picture of the wire configuration that worked for your light?
