Just installed the rear dome light for 2024+ Tacoma
tacomasport1121
Robert
2024 Tacoma Sport
Meso and Lexland are very similar. I think Lexland just had a bad batch of wire harnesses sent out. If you don’t want to fix yours, contact Lexland. If not, it’s an easy fix. Just push the black and blue wire pins out and swap locations. I pushed the pins out with needle nose pliers and gently pulled at the same time. Easy quick fix
Lexland_Official
Lexland_Official
Devin
Tacoma TRD Sport
Bought and installed one of these weeks ago. Took longer than it should’ve though because it was mis-wired from the factory. Luckily I didn’t have to solder anything
Do you still have any issue?
Lexland_Official
Lexland_Official
Devin
Tacoma TRD Sport
FYI it seems your latest batch isn’t wired properly which is causing issues when installed.
If you have any issue,please feel free to contact our customer service team,they will help you within 24 hours.
Stingertron
2026 Tacoma TRD OR
Silly question but which end did you swap? The big or the little one?
tacomasport1121
Robert
2024 Tacoma Sport
I heard they were coming out with a version 2.0 that should fix it 👍. I’ll keep you posted with what I find out.
Should be full disclosure that you're sponsored by, biased, and thus promoting Lexland.
28Gauge
2026 Toyota Tacoma Off Road Premium
I tried installing this today, but the unit didn't work as expected. It would stay indefinitely with the doors locked. If you turned it off, it of course wouldn't turn on when the door was opened. Beats me what is wrong, so I gave up and reinstalled the OEM dome light. I should note that I bought some door puddle lights at the same time and they work just fine.
Lexland_Official
Lexland_Official
Devin
Tacoma TRD Sport
Hi,please contact our customer service,our team will give you teh solution asap,thanks!
