2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it?
DeadSetMonkey
Denver, CO
I have a 2024 Trailhunter. I am interested in installing ditch lights.
And have prewired aux switches to use.
1. Anyone done this yet? If so, any write ups?
2. Anyone swapped the actual in dash switch? I'd be intereste in installing one that said "ditch" instead of "aux" on the surface.
Cheers,
Daus
tnjwinters
Tim
2017 Tacoma TRD Pro, 2024 Trailhunter 6’
I would be interested as well. I’ve heard that the lights may interfere with the snorkel and hood opening.
Taco Azul
MP
Portland
Did it on my Trailhunter. I used the front harness, that’s right behind the driver side headlight. It can be hard to find at first, as it’s under some other wiring. I used Aux 3. This isn’t really a write up, but I’m not sure what else there is to say.
Ruissimo
Rui
New York
Same as the post above, except I used AUX 1. Running the wires in the engine bay is the hardest part. I used the same pigtail connector behind the driver's side headlight.
As for interference with the snorkel, depends on the size of your ditch lights. I would think anything under 3" will be fine. My 3" Rough Country Osrams barely fit while the hood is opened to the first notch (see pic). On the second notch - the one where the hood is open higher (not shown), it will definitely touch. If you're worried about someone accidentally accidently knocking the ditch light into the snorkel, you can try taping the second hole shut with some black duct tape or electrical tape. If it did happen, I don't think it would do any damage, but it would definitely mess up the position of the light in the housing.
2024 Tacoma 2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it? 461017512_542713131670045_5145775032991142951_n
2024 Tacoma 2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it? 461254507_1248318019688925_4175868337279597663_n
2024 Tacoma 2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it? 461248846_897997698933733_1315928467114847078_n
2024 Tacoma 2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it? 461201677_1544893266412743_3101497018411656010_n
RESQCAT
Dennis
North Bend, WA
Thanks for your reply. Just got my CaliRaisedLED Ditch Light set... and as I brought the box inside to unpack it, I realized that the snorkel might interfere. I wrote a message to them and then saw your message above. Will post something when I figure this out.
CRUZN4U
San Diego
2024 Tacoma OR IforceMax Hybrid
Cheers,
Daus
Hello, this is my first rodeo. I just received my caliraiseled ditch lights and would like to know, where would I connect the wires to the battery when the battery is under the backseat? I appreciate any help on this matter?
RESQCAT
Dennis
North Bend, WA
I think Cali said to wire to the fuse box under hood. Check with Cali. I have not wired mine in yet but I think that is what I was told...
While I have not wired them in yet, I installed the ditch lights and brackets along with a Redline strut kit. I posted the hood hinge bolts that I recommend using (M8x25 or M8x30 with washer) if you do both. Those two brackets add 8.14mm of thickness. While you might use OEM bolts for one, if you do both I do not believe the stock M8x20mm is sufficient to safely mount both brackets under them.
RESQCAT
Dennis
North Bend, WA
My CaliRaised bracket cleared the snorkel by a small amount, but did not touch or come close. It is solid so there is no problem in my opinion. Cannot speak to other brackets. Also, CR makes clear to use THEIR bolt to mount the light bracket onto the hood hinge bracket as the ones that come with the lights themselves are too long and may damage your truck. You do use the light bolts to attach each light to its mount (one on each side of light).
SmokyMtnTaco
Rob
East TN
2025 Toyota Tacoma Trailhunter, 2018 Toyota Tacoma TRD Sport
Cheers,
Daus
I'm a few months late to the party, but I'm publishing a youtube video today detailing the install on my 25 Trailhunter with the problem solved (in my mind) about the snorkel. Let me know what you think:
src=""
OFFROAD LIGHTS: 2025 Toyota Tacoma Trailhunter in BEAST MODE!
I did discover something about about the aux connector port that everyone tends to use just to the left of the washer reservoir. My advice, don't use that aux connector for front accessories, use that for the jumper for rear accessories.
It's not being talked about much in the 4G forums or on youtube, but I highly recommend informing yourself about the 'traditional' aux connector before wiring anything up to it:
src=""
MUST WATCH: Why Your 2025 Tacoma Rear Auxiliary Port Has NO POWER?!
2024 Tacoma 2024 Tacoma Trailhunter (or other hybrid) Ditch Light Install - Anyone done it? Screenshot 2025-04-09 164328
father
Anthony
Massachusetts
2026 Tacoma Trailhunter Long Bed
How did you connect the wires to the battery?
If you have pre-wired Aux switches, they're already powered. You wire the positive and negative of the lights to the power and ground of the Aux switch that you want to use. It's that simple. There is no wiring anything to the battery.
