Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter
portalhunter
Bob
Anyone else using the JBL speaker dock for something other than the speaker? I kept seeing roof mounts and magnetic pads for the Starlink Mini and wondered why nobody was using the rigid quick-release receptacle Toyota already put dead center on the dash, aimed at the windshield.
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter A7V03194
Turns out a Defender shop in Canada had the same thought. Broken Rover is a Land Rover parts outfit, and the designer, Jeremy, actually launched the bracket in a thread on another Tacoma forum back in January with the line that he's a Land Rover guy intruding into the Toy world. It snaps into the JBL Flex receptacle with the Mini attached, and the dock's own latch holds it.
How it works day to day
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter A7V03195
Install is genuinely about two seconds. Press the factory release button, lift the speaker out, snap the bracket in. Removal is the same button, so the whole assembly comes out in one motion when the truck is parked somewhere I'd rather not advertise a satellite dish. That stow speed is the real feature for me. No adhesive residue, no drilled holes, no suction cup baking loose in the sun.
The bracket itself is a 3D printed part, layer lines and all, with a Made in Canada sticker on the back. Printed thick through the clip sections, and it's rigid plastic seated in a rigid dock rather than a friction mount that works loose. Ships with all hardware plus a release stick you don't really need since a finger reaches the release tabs fine.
Numbers and fitment
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter A7V03192
Roughly 300 grams total, so the dock doesn't notice it. $60 CAD from their site, ships from Canada.
You need the JBL dock, so Trailhunter, TRD Pro, or a JBL-optioned Off-Road. One honest caveat from the designer's launch thread: the PeakDo battery adapter variant pushed the dish into the glass on a 2024 OR, and Jeremy confirmed the standard version is the safe fit. Mine clears fine on the Trailhunter. The dish is also looking through glass at whatever angle the windshield gives it, so you trade some sky view for the convenience.
Wrote up the full review with install photos: https://truck.bdigitalmedia.io/blog/starlink-mini-dashboard-mount-tacoma/
Curious what this crowd thinks about dash mounting vs roof for the Mini, and whether anyone's run one through a hot summer yet. Arizona dash temps are my open question.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Your timing is great for me. We got our Mini recently and want to have two ways to mount it, on the dash and inside a roof box. This looks awesome if it will fit our Mini.
With Gratitude!
-Lauren
Cabby30
CA
2024 DCLB TRD OR
I'd want to throw a matte black vinyl on there for the reflection on the windshield. However, I also would be concerned about it over-heating. Unsure what your use case is however.
JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
It's been fine so far this summer in Northern UT, FWIW. We have 2, and both have held up.
lauren01
Lauren
Ventura, CA USA
@portalhunter ordered the JBL dash mount from Broken Rover (thanks again).
Had my eye on a mount from BulletPoint but we had to wait to receive our Mini to see what the bracket configuration would be. Broken Rover also has a BulletPoint mount. We decided to go with the mount to the JBL spot to avoid interfering with the gadgets already hogging the Rubigrid.
As far as heat concerns go, my gut says the dash mount will be cooler temp than when we opt to mount on the underside of a Roam case on the roof. Those cases get pretty hot inside. My windshield has a 70% + UV blocking tint added, and the air conditioner vent is right there. In winter we’ll be careful not to heat blast the antenna. So may be remounting on a tablet type mount via Rubigrid if needed. Or Roam case may be better at that time of year.
Just am stoked to feel safer when we two women travel. Pew pew and better comms w/GMRS and satellite are helping us feel safer.
portalhunter
portalhunter
Bob
no prob! i just drove from SD > PHX across 110+ degree stretches with it in this spot, no issues. I had it in my GFC for like 18 months - trapped between the roof and the mattress. This thing can withstand serious heat. Inside the cab will be no prob...
Will721
Will
Quad Cities
2025 TRD OR
Im waiting for a non jbl variant, then I'll mount my mini. Just a fyi to those doing the swap, you can by silicone sleeves cheap for the mini off Amazon. That way there's less white to clash with the interior.
The mini is a better alternative than the oem LTE based wifi, as it will get signal when there is no cell service. Plus, combine it with some of the varios android auto little black boxes can disconnect your phone from the truck completely and turn your head unit into a true multimedia center.
portalhunter
portalhunter
Bob
good idea… didn’t even know these covers existed. ordered one, should help also desert running, the bottom of the starlink is super close to the window. enough to touch during hard hits.
Pappy
Intermountain West
How did it work? I have a conflict between Android Auto and my Starlink. If the truck is running I can't use my Starlink.
portalhunter
portalhunter
Bob
works great what kind of conflict do you have? You can’t connect to the Wi-Fi network that the Starlink creates and wireless CarPlay or android auto at the same time. I have a separate android auto device that I connect that takes over the full 14 inch screen. This allows us to watch Netflix while driving using Starlink
Pappy
Intermountain West
Correct, the Starlink will disconnect the WIFI when I run the truck and my phone connects to the dash. I didn't think of trying it with a second device. I'll try it with the tablet and see if the issue is just the phone.
Awger
Kelowna BC
24 Tacoma
I recently purchased this mount system for my starlink mini and it’s great on asphalt, but on any kind of rougher road its not great.
I tested it last week and the starlink plus the adapter makes the whole dash shake quite a bit. I felt like the whole setup was going to vibrate my dash apart. So I’m only using it on smooth roads. It’ll go up on the roof when I need it during travel as that seems more secure.
Thought everyone else should know who’s considering this product that it is not for offroad use by itself. I also had to add felt pads to my starlink so that it wouldn't rattle against my windscreen.
portalhunter
portalhunter
Bob
take a look at the silicon covers they sell on Amazon. Perfect fit
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Yeah, that same issue and added a support to the front. Better, but I wouldn't do any hard offroad with it.
https://www.tacomaworld.com/threads...peaker-receptacle.872720/page-2#post-31176514
After considering my use cases (don't expect to need starlink while I'm driving very much) I went with a rooftop magnetic mount.
soupy1234
Show Low AZ
Phone can only connect to one WIFI point. If you want to use it with Starlink and Android Auto or Carplay you need to use a USB cable to the display head.
