Does anyone else use Lucas Oil Stabilizer?
Scottyboy24
Christopher
Pensacola, FL
2024 Tacoma SR 4X4 with XP package
Has anyone else ever added Lucas oil stabilizer to their oil? (I have used it in my 2011 Prius it's entire life. 212k on it now.) I also used it on my 1997 F150 and it stopped the truck from burning a qt of oil between changes. - Just getting some input before using it in my 2024 Tacoma. Thx
Mercedes
≈39N
2026 TRD Sport "Mercedes"
I do not use engine oil or fuel additives.
I'm using a leading brand name, synthetic oil, 0W-20. It's not the best oil. I do feel it's one of the top brands and has one of the best packages. Several companies make excellent oils.
I do perform engine oil analysis. Wear materials and chemical makeup of what's coming out of the pan are both excellent and incredibly boring. Nothing is telling me I need to add anything, change the brand or type.
I compliment use of the oil with a Top Tier fuel, the highest octane available.
https://www.toptiergas.com/
The Toyota owners manual does not mention oil additives, if they are required or should be avoided.
The Toyota owners manual does mention Top Tier fuels and recommends using them.
https://pqia.org/
Scottyboy24
Scottyboy24
Christopher
Pensacola, FL
I compliment use of the oil with a Top Tier fuel, the highest octane available to me.
https://pqia.org/
Thank you
AmbyBomb
Nick
2026 Tacoma TRD Sport
Why do you want to use it? I don't get adding something to your oil just for the sake of adding something to your oil.
Will721
Will
Quad Cities
2025 TRD OR
I would not put that crap in a new engine. Machine tolerances are far too tight to need it. Lucas oil stabilizer just thickens the oil. It has been proven not to increase lubricating properties of modern oils. Running oil that is too thick in tight tolerances causes aeration, which is tiny bubbles in the oil. Those bubbles breaks up the thin film of oil between bearings causing metal on metal contact. Its likely it would cause premature wear before any actual benefit.
That said, I do use it in other things. Like my old tractors and truck engines. Just to give the old loose engines a bump in oil pressure.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
Couldn't agree more with Mercedes here. I do oil analysis also, less now since break-in. Good oil doesn't need any help with additives. Additives can diminish the total chemistry of the specific oil used. Good oils are balanced, application always dictates chemistry. Just get a good oil.
Slappy
tacoma , highlander
Toyota oil is a high moly oil
they would be using the high molybelium blend for a reason .
just saying
