disabling DCM / telematics in 2025 Taco
Singha
Siri
NY
25 Taco TrailHunter, 07 FjC, 00 100series, 04 Lx470 (100series), 88 Samurai TT
Has this caused anyones remote start via the key fob to stop working? Toyota claims the DCM is required for remote start to work at all even from the key fob as without the 10 year free trial or paid subscription to Connected services, you will lose access to remote start.
I Installed the AHH connector and NOW my remote start VIA key FOB is also not working. I have confirmed it. And I ran a full scan, codes are showing that there is no communication with the Telematic. No other codes or issue. I would like to have my remote start back with out Toyota getting my driving info.
Seems from this older Tundra Forum thread that the DCM functioning correctly is required to use the key fob to start. Though the consent to use Connected Data services to use the fob remote start seems to have been discontinued.
Unless declining the Connected Services on the newer models is just a placebo (honestly wouldn't be surprised). And you're now seeing the actual DCM not being used.
Definitely a link from the DCM to the ECU that the key fob is using though.
fredygump
Darren
Minnesota
2026 Tacoma SR5, 2016 VW GTI
I am confident that your vehicle is constantly/ regularly transmitting data to Toyota no matter what you do, unless you disable it yourself.
Their legal justification/ argument is to point out that a person who does not set up an account is identified as a "guest". Because the vehicle is operating under a "guest" user, the data they collect is not "personal data". It is "anonymous" data, not personally identifiable!
I am pretty sure that an insurance company (or other company?) that is buying driving data doesn't care if the driver is identified or not. If they see a driving event they don't like, they could penalize you, whether or not it was actually you. So yeah, even though it is not technically "personal data", the data is connected to the owner of the vehicle.
The data becomes "personal data" when you identify yourself as the driver! And when you identify yourself (i.e. setting up the app), you consent to the tracking stuff.
Once you create an account, or a family creates multiple accounts for each driver, then Toyota can separate the driving data into individual reports for each driver. Isn't that nice of them?
I do not see how Toyota has any ability (or incentive) to remotely disable the transmission of cellular data from your vehicle. They just receive it all of the time. If you don't like that, you have to stop the transmission at your vehicle.
I disabled my DCM, so this isn't an issue for me.
Was just pointing out that there's definitely a connection between the key fob remote start and the DCM.
iron.head
Michigan
2025 Tacoma TRD Off-Road Premium
Could somebody confirm if autoharnesshouse.com
Toyota Vehicle - Telematics DCM Bypass kit
is breaking the microphone function? Thank you.
fredygump
Darren
Minnesota
I suspect you somewhat misunderstand the situation.
The autoharnesshouse.com kit does not deactivate/disconnect the DCM, because DCM is deactivated when you unplug the cables or pull the fuse. You do not need to buy anything to do the disconnect.
What the kit does is it restores the functions that you would otherwise lose by just disconnected the DCM.
So yes, you need the kit if you want to keep those functions.
iron.head
Michigan
I went with this solution (bought it, even though truck is still on the way): https://www.autoharnesshouse.com/store/AHH-DCM77
This supposedly works and no power goes to the DCM at that point, so the cellular modem is genuinely dead.
EDIT: This does not seem to work properly. May try it again but it seems the microphone does not work with it. Same behavior as pulling the DCM fuse.
@fredygump if you see Page 1. Microphone did not work with the harness.
