disabling DCM / telematics in 2025 Taco
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
Is it also necessary to call via SOS button and opt-out from toyota connected services?
pchi
Hawaii
24 Tacoma
Wouldn't stuffing some RFID cloth into the shark fin cover block all signals?
GPS and radio/music can be through your phone. Or if you're old like me, music through thumb drive.
ryd34lyf3
Charlie
CA
2025 Tacoma TRDORDC
Excellent write up by the original poster! I bought the harness from Auto harness house and I want to know is that harness garbage or not? Before I tear into my dash. Thanks for those keeping this thread on track.
Garbage? Like the AutoHarnessHouse harness? No, it works as advertised. It removes the power to the DCM so that you're not transmitting data while tricking the ECU into thinking you're out of cell range and not reporting any CELs.
You also don't have to tear into the dash. You remove the panel where the wireles charger/USB chargers are and remove the connectors from the DCM.
Dayen
Daniel
North Kingstown RI
2024 Tacoma SR 6MT, 1985 BMW 316 5MT, 2004 BMW 325i 5MT (sold)
Did you get around to testing with GPS still plugged in? That would be the middle wire correct? I appreciate you guys sharing this information. Thanks
GPS plugged in was what I needed to make Android Auto work again, that's been good. I think I need to buy and install the real harness to delete telematics, I'm skeptical that the grounded out signal wires are fully cutting it with how I've gotten some "your truck needs service soon" phone calls and emails. I also am due for my 25k mile service soon, I should go to the dealer and tell them explicitly that I want to opt out of all data collection.
I have unplugged and ran the cap system here but everything is still the same. The truck still shows how fast you're going over the speed limit as well as the stop signs etc. At this [oint if the only recourse is to take the fuse out. Any help would be swell
That's done off of the vision system that controls the brake assist and some of the adaptive cruise control stuff. Nothing to do with the telematics
NoSlushbox4Me
TX
2025 TRD Sport 6MT
I did this on my MT truck, using the Amazon parts and leaving the middle connector plugged in. So far I notice no negative effects. With the connector housing of the Amazon cable removed, I have some doubts that the cables will stay connected to the unit so I'm looking into a replacement housing to make it similar size to the connector that can be slipped over the harness end and zip tied to the middle GPS harness connector. Maybe a piece of flexible tubing would work well.
JFFRT24
Jose
Calgary, Alberta
stagecoachleathers.com
24Tacoma TRD O-Rd
Much appreciate this information. Since I bought this truck in 2024 my insurance has gone up every year. Really got mad once I found out what was causing it. Going to do this.
JFFRT24
Jose
Calgary, Alberta
24Tacoma TRD O-Rd
I covered my camera and that other unit behind the dash with some vehicle wrap. Pulled the fuse and.... The truck went nuts with Warnings and lights on the dash. Considering what these POS INSURANCE COMPANIES RAISED my Policy; I can live with the Chrismas tree dash.
JFFRT24
Jose
Calgary, Alberta
24Tacoma TRD O-Rd
Only one poster has mentioned the AHH bypass didn't work for him. I couldn't see if he updated his post yet.
Pulling the fuse kills the front (right? maybe left?) speaker and the microphone capability. Which is why the AHH bypass is recommended.
NHEric
Eric
New Hampshire
2024 SR5
I have installed the bypass harness (two piece set) I left the other three single plugs alone. Everything works perfectly, except of course anything that requires a subscription. Which I never used from day 1. I figured to purchase the harness because I am well over $45K into the truck already, why live with any kind of warning light, loss of useable functionality or other thing I actually use. In addition, I am of the opinion that simply disconnecting the three single wires leaves the dcm subject to viewing via the OBD port - do I know this for a fact? Nope, but why not ensure the thing is completely dead.
fredygump
Darren
Minnesota
2026 Tacoma SR5, 2016 VW GTI
I've had my SR5 for 1 week, and I just completed the DCM disable procedure. The OP's write up was handy for that.
I used the Autoharnesshouse kit and pulled 2 of the 3 antenna wires. I left the middle (grey) cable connected for GPS on Android Auto. I tested with it plugged in and unplugged. With it plugged in my speed indicated on the GPS app was very stable. Unplugged was only slightly worse, but I figure I'll keep that function.
Lol! I did the research and found out about the DCM disable before buying my truck!
This whole GPS tracking thing--it all started for inventory control. Twelve years ago I was an inventory auditor. I mostly did John Deere dealers, but a few car dealers as well. Just walk the lot, scan unit SN or VIN, and ask the dealership for dispostion of units not found on the lot. That job is basically gone now because of GPS tracking on new units!
It makes sense that if they are going to have a GPS unit to track floor plan units, they might as well add more functionality to it and tell customers it is a feature. But I don't want or need those features, and being connected to the internet creates risk. If it is on the internet, it can be hacked. And if it can be hacked, it will get hacked eventually. So I'll just opt out.
So yeah, I don't think it is some kind of conspiracy. Just businesses protecting their bottom line. This stuff lets them control inventory without expensive audits, they can prompt lease holders to do basic maintenance, and they can locate vehicles they are financing in case of default.
But I'm not leasing, and I'm not financing through toyota. So I figure they don't need to know where my truck is anymore.
Singha
Siri
NY
25 Taco TrailHunter, 07 FjC, 00 100series, 04 Lx470 (100series), 88 Samurai TT
Just installed the two plugs from the kit from Auto harness house.
Super easy.
I wrapped the upper part of the handle with electrical tape (two wraps). To reduce the chance of marking it up.
Used a small "L" pic to slowly pry the charging pad from the top side (right below the HVAC controls). Prying across the top of it. Then put the truck in neutral to make more room to work. Slide the top of that console toward the rear of the truck and slide it out. Unplug the 3 connectors (Wireless charger, USB C, and the cig). Use the tip from the pic and push the small white tabs (two) to loosen the harness strap/clip tie down. Take a long flat small head screw driver and push the grey (big plug) lock in, use the same screw driver and use the tip to slowly pry the plug away from the DCM (go back and fourth on either side of the locking tab). Should unplug from the unit easily. Use the long screw driver to also push the locking tab on the small plug. The plug can easily be pulled down and out of the DCM with your hand.
Plug the Auto Harness plugs and your done.
Hardest and took the longest was trying to get the wireless console back in under the HVAC controls and into place. Easy coming out, so pay attention how you work it out to clear the HVAC controls. Took a whole 10min to get it back into it spot safely without scratching up anything and breaking the HVAC buttons.
