Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter
Pappy
Intermountain West
Phone can only connect to one WIFI point. If you want to use it with Starlink and Android Auto or Carplay you need to use a USB cable to the display head.
Which is what I always do.
TacoFish
Bill
Snoqualmie, WA
2024 Trailhunter LB, 2023 Audi Q4 etron, 2025 Subaru Outback Wilderness
I have had my Starlink mini mounted to my roof rack using the the Veritas Vans mount and rack mount kit. I run the power and ethernet cable through the back window and cover that with XFasten Transparent Window Weather Sealing Tape. I plug the power into the Cig Adapter or USB-C. I plug the ethernet cable via USB-C adapter into my iPhone. Then it can be connected to the vehicle via WiFi. I have been looking for a black or gray cover that would fit over the Veritas Vans mount given it does not really blend in with black roof rack and canopy (white on black/bronze oxide). I think I will get this adapter and get the black liquid silicon case. 122 degrees F is the redline on temp for the Starlink mini. I would probably remove and stash it when I am not in the vehicle. That looks much easier with the adapter vs the roof rack mount.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Got my Broken Rover 3D printed mount. Quality is so-so but design and function is good.
I spent some time shaving the rough edges and reinstalling on the Mini a few times. My tiny brain finally realized my copy will only lock into the JBL dock if I press it in without it being mounted on the Mini first. Once the mount is in the dock, then it’s easy to slide the Starlink into place and lock in.
Fortunately, the mounted Mini fits my dashboard and is over top of my existing bullet point mounts, so it is not too busy and there is no interference.
I had bought a silicone sleeve, but returned it because it’s too thick and butts up against the windshield, in a way that interferes with the installation of the plane mini. I have ordered a ranger wrap to put on. Another problem with the silicone sleeve is that it was too reflective despite what the seller on Amazon claimed.. once I get the Ranger wrap on, I will post pics.
TacoFish
Bill
Snoqualmie, WA
I have on order, should be here next week. Great feedback on the silicone sleeve. I was about to order that as well, now I will not. I look forward to your feedback on the ranger wrap.
lauren01
Lauren
Ventura, CA USA
This afternoon the Ranger Wrap arrived. Thought I ordered black Multicam but regular Multicam is what I got. It’s easy to put on and repositioning is easy too. Jen (wife) helped me by holding one end up a bit while I maneuvered the pieces onto the antenna.
We did the back bits first, then the one-piece front, so the fold-down sides would cover any small mishaps. Smooth it a few times to warm the adhesive and it will stay put in the corners. You can see where I had not smoothed it yet in one corner but it’s fine now.
There are a few bits we didn’t use because we have the Broken Rover mount.
Sleek and non-reflective beats the bulky distracting silicone sleeve that I tried last week. The sleeve would be good elsewhere like outdoors. Buy once, cry once. This truck tends to make my wallet cry often.
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter IMG_0548
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter IMG_0549
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter IMG_0551
TacoFish
Bill
Snoqualmie, WA
Thank you for the Ranger Wrap update. Would you be able to take off the Ranger Wrap, then re-add it repeatedly? I ask in case I need to put the Starlink Mini back in my Veritas Vans mount or if temps get extreme while operating it.
lauren01
Lauren
Ventura, CA USA
They indicate Yes but probably there are limits to how many times you can do that since it is just adhesive.
https://rangerwrap.com/pages/faqs
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter IMG_0558
OminousSkitter
Alaska
Are the screws on the mount how it locks in place so it doesn't come out with every bump?
I'm considering 3D printing something similar with better quality filament and printing (every picture I've seen screams a poor/quick print job). Found some JBL speaker delete templates--some with those screws and some without, and I assume those screws are required to secure it.
lauren01
Lauren
Ventura, CA USA
No screws — it slides into place.
OminousSkitter
Alaska
Hmm, the picture makes it look like the mount has screws/bolts/metal shafts--not that screw into the dash to secure it but for a locking mechanism. Are they not needed?
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter Screenshot 2026-08-12 at 21.32.13
Edit: After looking at this picture it looks like yes, those are how it locks in.
2024 Tacoma Starlink Mini mounted in the JBL speaker dock: running the Broken Rover bracket on my Trailhunter 1786599629447-o4
lauren01
Lauren
Ventura, CA USA
Yup, you figured it out.
They would hold better if they were smoothed out - pins instead of screws - IMO.
OminousSkitter
Alaska
Thanks. I should be able to make my own starlink mount pretty easily with better printing and filament. I'm considering that or just a ball mount so I can easily swap out what is up there.
PullinDoubles
Bobb
2024 Toyota Tacoma TRD Off-Road i-FORCE MAX
This may not be completely relevant to your post. The other day the wife & I went to T-mobile & got new phones. Samsung Galaxy S26 Ultra phones super deal just pay tax. Anyway, she told me about the new T-Satellite with Starlink - The largest mobile + satellite network that keeps you connected where it wasn’t possible before. It activates automatically so you can use apps, text, voice chat, share locations, and more. https://www.t-mobile.com/coverage/satellite-phone-service
Included in some plans, not ours of course. But you can add it for like $10 a month!
