5w-30
IDontWorkForTheWaterCo
2026 Tacoma SR
On the Banks iDash. I also have temp sensors going to my MT and Rear Diff fill plugs.
Regarding weights being weights and they're all the same, this is unconfirmed and not published, but ratings were posted on the forums, a reply from Valovline support regarding their HTHS values.
https://bobistheoilguy.com/forums/t...d-protect-hths.399575/?utm_source=chatgpt.com
Letting ChatGPT do some of the research for me (this is a snippet)
So if those Restore & Protect numbers are real, the practical interpretation would be:
Restore & Protect 0W-20 at 2.65 cP
This would be a fairly fuel-economy-leaning 20-grade. It would still meet the SAE 20 hot-shear floor, but it would sit close to the minimum, suggesting Valvoline optimized it more toward low drag / efficiency / cold-flow friendliness than toward maximum hot-shear thickness. That does not mean it is “bad” or unsafe if your engine is designed for it; modern OEMs often specify oils in this range intentionally.
Restore & Protect 5W-20 at 3.17 cP
This would be a much stouter oil under load than most people expect from a 20-grade. A 3.17 cP HTHS sits well above the SAE 20 minimum and even overlaps the broader low-HS/low-SAPS European fuel-economy territory where minimum HTHS is often 2.9 or higher, depending on spec. In practice, that would usually mean thicker oil film under hot load, potentially a little more margin for wear control, noise damping, and oil consumption resistance, at the possible expense of a bit of fuel economy.
Oh definitely. There are "light" and "heavy" KV100 scores on all grades. I just meant from a practical stand point, it would tough to measure a big difference in performance between a 0w20 and a 5w20 given that they will both perform as 20's at operating temperature.
An argument could be made that on average a 5w20 could potentially be slightly more sheer stable than a 0w20 do to less friction modifiers.....assuming the 5w20 is a synthetic.
Andrace
2024 TRD Off-Road 6MT
What actually matters is the temp of the oil at the rings, in the bearings, and in the turbo, which is different from where it's measured at the sensor. Speed Jr mentions this in a video, some capillary tubing used to sample oil from the rings. will try to find that.
Andrace
[QUOTE="IDontWorkForTheWaterCo, post: 271117, member: 10817"
Could be an argument to be made that on average a 5w20 could potentially be slightly more sheer stable than a 0w20 do to less friction modifiers.....assuming the 5w20 is a synthetic.
[/QUOTE]
That's the primary reason I opted to go with 5-20, it's more shear stable and offers more headroom in conditions when it really matters.
2026 Tacoma SR
Temp is very important. Back in 2017, when Toyota introduced the first Dynamic Force engine (A25A) lots of people freaked out when they saw the 0w16 recommendation. But fast forward nearly a decade, and you have Camrys and RAV4s running around with 200k on them. 0w16 is a thin oil. But when your running oil temps of 170° to 190° that 0w16 stays "thick" at operating temperature.
But I'm not a thick vs thin kind of guy. I say run whatever viscosity that makes you comfortable.
shackley
www.swxrflab.net
Who's using 5w-30. Lots agree that 0-20 is for CAFE standards or EPA BS. I believe in 0-20 as much as I believe in 10k oil changes.
Any of you guys running 5w-30? Have you done an oil analysis?
Getting ready to do my first oil change at 1k, then switch to 5w-30 pending real world reasons not too?
Well, if 0w20 is for the CAFE standards, I haven't seen any difference in mileage running 5w30 this summer. We have had some 100+F days, so I think it's good for the summer. I used 0w20 in the winter. We get into single digits at times in the winter.
24tacoman
2024 TRD OR 6M
5w30 Used Oil Analysis shows better wear than 0w20 previously did. I will continue to use it. Made a whole post about it for more information.
2024 Tacoma 5w-30 Oil Analysis
DENNISD
Dennis
Omaha
It should be considered a book at this point
Maybe we misinterpreted the "5w-30" title? Instead of the weight of oil, they meant page numbers..........
8 pages to go
Who's with me!!
shackley
www.swxrflab.net
I assume you use in in the Canadian winter too.
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Tacoma4g would definitely save some hard drive if we could delete yours and Maxx's non contributing posts all the way back to 2024.
DENNISD
Dennis
Omaha
Or.....................we could just go with what the manual suggests and delete all of the posts. Think of the hard-drive space we'd save.
So, if we're going to settle this based on saving server space, I assume the debate is officially over and we're taking Toyota at its word? 🤔
