Trucks without factory aux switches
JZE
Alberta Canada
24 Tacoma TRD Off-road
So I have a base TRD off-road without the 3 factory aux switches.
I’m in the process of installing some LED ditch lights and I noticed the wiring and plugs under the hood that I believe are used for the factory aux system, so I looked in the fuse box and the fuses for aux 1, 2 and 3 are in place but the relays aren’t.
There does appear to be wiring pinned into place where the aux relays would go in a truck that came equipped with the switches.
So I’m wondering if I were to plug relays into those spots if I would be able to use the factory aux wiring.
Has anyone done this or have any insight into whether it would work or not?
One thing I haven’t checked yet is if there’s any wiring in the dash for the switches to plug into.
MNTBKR
Luis
Central, FL
Following, hope we get an answer add in in the same boat.
Kdbradley85
2024 Toyota Tacoma TRD OR MT
I saw this video from Cali Raised a few days ago replacing the blank switches, and I believe the truck they’re working on is an SR5. Might be helpful.
Gurvy522
Chicago, IL
I can confirm on my Limited there wasn't any wiring there.
The fusebox cap did have the diagram for the Aux relays - however, where they were supposed to be located (within the fusebox), there was no wiring or female relay connectors. Just a completely empty row. This was also confirmed by not having any loose wiring behind the switch panel in the cab.
It is possible that some trucks may have some of the wiring there. It seems like there is no rhyme or reason on why certain trucks have various additional parts / wiring (ie crossmember on Limited Hybrid, hole plugs for control arms, etc).
Can you post some photos to help illustrate? It appears that various vehicles are shipping in various partial support setups and I'm curious (as I am certain others are) at what point things exist or not and can be tapped into.
For my Limited Hybrid, no aux switches, but the wires to the plugs are in place, yet the fuses and fuse row are absent in the engine driver's box.
2024 Tacoma Trucks without factory aux switches 1728326475573-zq
2024 Tacoma Trucks without factory aux switches 1728326744741-w4
2024 Tacoma Trucks without factory aux switches 1728326837975-x
Norman
Norman
Virginia
24 tacoma trd or
For thos asking the question you should be able to relay box should just have to be plugged up. For those that have the relay section without fuses and aux button I should be able to tell something being of next week waiting on relay and aux switch from cali
Delta1Seven
Hoping you can get this figured out and provide an update!
Well, I've got the Aux switches. For my ditch lights, I wanted a dedicated illuminated switch and bought one from Cali Raised. Thus, when they're on, I've got a blue light.
It works great.
