Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
Our new Mabett Tailgate Anti-Theft Lock is now available!
It adds a physical barrier around the tailgate hinge area to help make quick tailgate removal more difficult, without changing how you normally use the tailgate.
Fitment Note
Fits 2024–2026 Toyota Tacoma. The protector uses the factory mounting point, with no drilling, cutting, or permanent modification required.
Tacoma4G Launch Offer
Save 35% and get it for $12.99
Product Link:
https://amzn.to/4qXdeyu
Use the promo code BSRXNRY8 at checkout to apply the discount.
Small Details That Matter in Daily Use
Extra Protection at the Tailgate Hinge
The bracket sits around the factory tailgate hinge area and adds another physical obstacle to quick removal.
For owners who regularly park outside, travel, camp, or leave the truck in public parking areas, it’s a simple way to add another layer of security without changing the tailgate itself.
Open and Close the Tailgate as Usual
Once installed, the protector stays in place and does not interfere with normal tailgate operation.
There’s no need to remove it every time you open or close the tailgate.
Removal Tool Included
We also include a 10mm L-shaped socket wrench, so if you ever need to remove or adjust the protector, you already have the tool on hand.
The bracket itself is made from carbon steel with a black powder-coated finish for everyday outdoor use.
Would You Add This to Your Tacoma?
Would this be something you’d install for a little extra peace of mind when parking your Tacoma outside?
Feel free to leave a comment below and join the Mabett 4th Gen Tacoma Garage if you want to see more early Tacoma product previews, selected testing opportunities, and member-only offers.
Will721
Quad Cities
Looks like a copy of the Cali-raised I bought. As long as the coating is good I'd highly recommend either. Easy to install and remove as long as you have the security torx bit.
cmillls45
minnesota
tacoma
Nice looking product Jeremy. Does it work for the auto tailgates? If so, I’ll buy it! Thanks, Chris
TX-BluStreak
Tom
Houston
25' TRD Pro - Underground
Everything looks like a copy of someone else's creation; you know what they say...imitation is the best form of flattery. I bought mine from Bobbercycle. It's roughly $20 more than Cali-raised and this one but it secures both the tailgate as well as the cable.
Mabett
Mabett
LA
www.facebook.com
CCLG
CC
2026 Tacoma TRD Off-Road, 2020 4Runner SR5 Premium, 2019 Tundra CM TRD Off-Road
Just bought one! Hoping the powdercoat is good enough to prevent rusts👌
Mabett
Mabett
LA
www.facebook.com
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I put the same on my truck. Took off the bolt months later and cleaned rust off the washer.
Mabett
Mabett
LA
www.facebook.com
Can't really tell if this will turn into a customer complaint yet. As you know, rust is pretty common.
Mabett
Mabett
LA
www.facebook.com
Yes I get that. Water runs out right there so I should put some sort of grease or silicone spray to repel water.
Exactly. :like:
Mabett
Mabett
LA
www.facebook.com
One small security detail: the fastener has a raised center pin, so a standard driver bit won’t work and removal requires the matching security tool, adding another hurdle against quick theft.
AZTaco
AZ
2025 Tacoma TRD Pro
Don't all new Tacomas have a locking tail gate? Locks automatically when you lock your doors. Does anyone leave their doors unlocked and then worry about their tail gate being stolen? What am I missing?
It's a solution to a problem that doesn't really exist
