marie_arb
Marie
Seattle, WA
Toyota
GIVEAWAY CLOSED.
How many of you are airing down before you head off-road? If you're not, or you're not sure why it matters, this one's for you.
One of the easiest ways to get more out of your Tacoma out on the trail doesn't cost anything; it's just air. Whether you're crawling rocks, running on sandy beaches, or bashing down a rough forest road, dropping your tire pressure gives you more grip and a smoother ride on any trail.
Of course, airing down only works if you have a reliable way to air back up before you hit the pavement. If you're currently relying on a portable compressor and spending twenty minutes filling four tires after every trail, there's a better way. And yes, it’s an ARB onboard air compressor.
This post covers everything you need to know: why an onboard compressor belongs on your 4th Gen, how to choose the right ARB unit for your build, and how to mount it cleanly in the engine bay.
Why Every 4th Gen Tacoma Owner Needs an Air Compressor
If you plan on airing down at all during the trail, you will need an air compressor. It's the only way to get back to safe highway pressures before you leave the trailhead, and with a proper onboard setup, it takes minutes. That same compressor also saves you on a bad day when you need to plug a puncture with a tire repair kit and air back up in minutes, instead of pulling the spare and calling it early. We’ve all been there.
Now let’s get you the right compressor.
Which ARB Compressor Is Right for Your Build?
If you head over to our website now, you’ll find plenty of compressor options. Not sure which one is right for you? Let me break it down.
Brushed vs. Brushless
Brushed motors are the proven, traditional design. They have been a part of our lineup and trusted on trails for years. They do generate more heat under sustained use, which is why they are built with hard-anodized cylinder bores and Teflon-impregnated carbon fiber piston seals to hold up under extended operation.
The newest brushless motors eliminate the internal friction that generates heat in a brushed design. The result is a more efficient motor that runs cooler, lasts longer, and delivers more output from the same power draw. The brushless lineup adds Electronic Speed Control that keeps output consistent as temperatures climb, and Smart Start technology that works with smaller charging systems.
Single vs. Twin
Twin motor compressors move more air and fill tires faster. The difference is noticeable mainly on larger tires or when you're airing up multiple vehicles. Single motor compressors are more compact, easier on your electrical system, and still plenty capable for most builds running tires up to 35 inches.
Onboard vs. Portable
An onboard compressor lives in your engine bay, wired directly into your electrical system. It's always there and always ready. If the 4th Gen is your dedicated trail rig, onboard is always the right call.
A portable runs off your battery via clamp cables and stores in a carry case. It's a solid option if you're not ready to commit to a permanent install or want one unit that works across multiple vehicles.
Mounting It Clean: The ARB Bracket for the 2024+ Tacoma
Once you've picked your compressor, the next question is where it goes. Modern engine bays don't leave a lot of obvious real estate for aftermarket accessories, especially a compressor.
That’s where our brand-new 2024+ Tacoma Mounting Bracket comes in. It's a fully bolt-on bracket that uses factory mounting points, so there's no drilling, no cutting, and no guesswork. The compressor mounts cleanly in the engine bay with easy access to the air couplings right under the hood.
The kit includes the bracket, a JIC-4 hose coupling, and a 1.0M reinforced hose so you have everything you need to complete the install. And it’s backed by a three-year warranty.
Quick note: this bracket does not fit hybrid models.
Giveaway: Win an ARB Tacoma Compressor Bracket
Now for the fun part! We're giving away one 2024+ Tacoma Compressor Mounting Bracket to a forum member. If you've been on the fence about pulling the trigger on a compressor install, let this be your sign!
To enter:
  1. Click on the link
  2. Comment which onboard compressor you will be running on your 4th Gen
  3. Entry closes September 30, 2026. The winner will be announced right here in this thread. Open to U.S. residents, one entry per member.
If you have questions about which compressor fits your setup, what the install looks like, or anything else, drop them below. Happy to help anyone figure out the right system for their rig.
Rmarin4272
Ryan
I’d love the twin brushless! Seamlessly mounted under the hood for a no hassle easy air job
Blue_Taco
Mark
DFW
I’ve been using an ARB portable single and love it but want to mount a single brushless with the new bracket.
FlyAngler
NH
Do you have a solution for the hybrids? Specifically, something to replace the onboard OEM compressor on the Trailhunter that is more powerful? Would be awesome if it could go in the same location, though I'd be interested regardless of where it would need to be mounted (but not in the bed -- that space is needed for other gear in my truck). I guess what I'm really asking about is a mounting solution for the hybrids... Obviously you have capable compressor options.
cyadoux
Nathan
Idaho
2025 Toyota Tacoma
The twin brushless is definitely what I would run. That bracket looks awesome!
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I echo this comment although I would wait for my compressor to crap out before replacing it.
Vicbespoolin
VICTOR
Bellevue, NE
2024 Toyota Tacoma TRD Offroad
The twin or single brushless air compressosr would be great! Cant make up my mind but the mounting bracket is a great idea! Good luck to everyone
Rubenc87
Ruben
2025 TRD PRO
Here you go
FlyAngler
NH
Can you tell me what I'm looking at? I see the external result, but can't figure out exactly where this is mounted. Starting to be hopeful! More details please. And thank you!
Here you go
