Alldogs rear coil springs
Tacocho
Alex
Portland, OR
Sorry for delayed response. Honestly, I'm still happy with the All Dogs Springs. The ride is great. I do wish the rear wasn't quite a high but the load capacity is substantially higher than the stock lift springs and THAT is a HUGE win. In stock form, my truck used to squat pretty bad with only 400-500lbs in the rear and now it sits strong. The cost difference between the TRD lift and the fact that I actually wouldn't want the truck any higher makes the All Dogs springs a win IMO.
Did you need to install the track bar relocation kit from Dr. KDSS? I’ve seen some people say the track bar relocation mount helps with stability over bumps
rybern
Ryan
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
I didn't. I measured and my rear wheels are within 1/8" of each other when measuring from the fender flares. This means my rear axle is within 1/16" from center. I find this insanely close. Any other reason kind of sounds like a sales pitch, but I could be missing something.
Deleted User 412290
Never even heard of this.
At what lift amount do they say this is a good idea ?
Tacocho
Alex
Portland, OR
I’ve heard that ideally you want your track bar parallel with the rear axle. Any angle deviating from parallelism can cause instability while driving over bumps. I might buy the springs then buy the track bar relocation later if I don’t like the way it performs. Just curious on others’ experience
Deleted User 412290
Food info! I'll have to check mine out. I only have 1/2 inch in the rear, but going up to 1 inch soon. Sounds like maybe too small too matter, but good to know !
