Banks Ram-Air Intake for the 4th Gen Tacoma. Everything you need to know.
MustardTiger
TacoMAX/SDuty/Dmax
Had an f150 ecoboost that I took in to ford for misfire, CEL, and low power (compression). Turned out the issue was a plugged catalytic converter...from a leaking injector(s). Anyways, ford covered the repair under the emissions warranty, but also informed me that my K&N oiled filter was insufficient at filtration and had "dusted" the engine (they had pictures to prove it), and thus my powertrain warranty was null and void. I got rid of that truck. From that day, I will NEVER use an oiled filter or any aftermarket air box intake contraption. Ever again. Simply not worth it. None of them actually filter worth a shit and if there is ever a sniff of a related problem, the manufacturer will void your warranty with the snap of a finger.
As a farmer, I take air filter maintenance very seriously on my equipment, especially the combines. The risk of compromising on filters or maintenance is just too high, and ungodly expensive. Turbocharged engines must have exceptional intake filtration, and restriction/dirt load of the filter plays a role in that. "High flow" means "high wear". Simple as that. You want your engine to last?...stick with the factory intake and filter. Inspect the filter (and intake tube) every oil change, replace the filter yearly, and make damn sure that air box is buckled up and sealed perfectly.
TacoMagnetic
Pasadena, CA
2018 TRD/OF, 2024 TRD/OF
TacoMagnetic
Pasadena, CA
I want to do this as well - I wonder if a tune is also required.
Maybe we get these done together. Mud Brothers join forces :)
No tuning will be required to run the intake. However, any tuning you add will be enhanced by the intake.
EagleTalon
2025 Toyota Tacoma Off Road
Any update on the Turbo Inlet Elbow?
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
I run TRD air filters bought from my local dealer.
Before I picked up my TRD Sport, I had them install a TRD filter and bought another one from my local dealer to have 2 at all times.
Heck, my 22 Corolla had a TRD air filter bought from the dealer. The dealership even put a TRD sticker saying it was a performance filter installed on the air box.
My 2016 SR ran TRD air filters all 8 years, my 2010 SR5 had K & N for 8 years. No engine issues.
my 05 X-Runner ran the TRD CAI box with no issues racing for 5 years.
ScottyMcfly
Scott
Western Mass
2025 Tacoma
I would switch to Banks parts in a second If I didn't already have a Sxth Element. What turned me off originally was the Oiled Filter. I never seemed to have luck with them, so I went with dry. Now I'm reconsidering going all @Banks Power with the boost tubes as well. Just not in the budget right now :(
gmalkmus
SW Missouri
You could always sell the SXTH and buy the Banks. That is what I did.
_NC_
2026 Tacoma TRD Off-Road premium (m)
What’s the filtration efficiency of the Banks intake compared to stock?
Banks Power
Banks Power
Jay
Azusa, CA
Do you have any dyno charts for the iForce Max?
Our published dyno data is the same iForce and iForce Max because the factory engine calibrations are the same. In other words, Toyota rates them at the same power output. The only calibrations that are different, are manual trans equipped trucks, TRD Pro and Trailhunter.
YotaGuy44
Eric
2025 Toyota Tacoma
Eric with Banks here. Tuning is not required in order to install and use our Ram-Air Intake or Upgraded Boost Tubes.
