Loading...
TacoBirdinNW
2025 DCLB SR5
"Creaking"
Tighten the bolts on the hinges
CharlieLed
Chucki
TN
2025 Tacoma
Sounds like the door retainer bar... squirt some silicone spray on the bar where it enters the door jamb and work it in.
Slappy
tacoma , highlander
you got a ghost in the machine
Frog Mack
Frog
Mississippi
24 Tacoma TRD OR, 14 FJC
Mine gets terrible from time to time. Driver rear door much worse than others, driver door no.2, hardly an issue with the other 2.
I keep dry lube in aerosol with me always, I work in very dusty environment, no grease or oil on anything. (Tailgate latch is worse than the Gen 2 and Gen 3). I spray the retainer bar, sound goes away for a few days, comes back.
How would tightening the door hinges help?
TacoBirdinNW
2025 DCLB SR5
The 10mm (I believe that's the size) hinge bolts come loose and the door will make that exact sound. Common issue. Tighten the bolts. If they aren't loose and it doesn't fix it then try lubricating the retainer bar.
Frog Mack
Frog
Mississippi
I didn’t spray for 3 days to show what mine is like.
Frog Mack
Frog
Mississippi
There is no way you could see my rear seats to know their condition. Ha
