Dead battery(s) iForceMAX
franx
Frank
Lehigh Valley, PA
2025 Tacoma Limited Hybrid
I do have my Porsche Macan on a trickle charger regularly since thats not my daily driver. My motorcycle is always on a trickle charger because they get dont get ridden frequently either and saves me buying a new battery all the time. Your best friend is a trickle charger for anything not used much, saves you a ton of money on battery replacements.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
yup. This my truck since Dec 1. Will be like this until spring to avoid the salt on the roads.
gpburdell
GA
3G Tacoma
I’m hearing lots of incidents similar to this from other owners. Wonder what the issue is. Bad batches of batteries during production?
Likely one part of the issue, and I believe Ford even did a bad battery recall in the past couple of years for this reason.
Still doesn’t really explain the low SOC some here are seeing even on their daily driver.
I used to do the same with the motorcycles I had over the years. Especially when I was in central NYS, less so in GA. Now I do the same with a wave runner and a boat, though the latter has a battery switch which eliminates all parasitic drain.
It’s expected that with enuf time normal parasitic drain will impact starting a vehicle, but it ought to take weeks not days.
Oh and do please be careful on two wheels. I only mention due to the coincidence that my wife volunteers at hospice and today a 28 year old succumbed to a crash related traumatic brain injury. Cagers here in ATL area are idiots.
Will721
Will
Quad Cities
2025 TRD OR
Possibly related, possibly not. For the guys who are reporting low charging voltage, are you guys driving in Eco Mode? I ask, because I've been paying closer attention to various changes and things my Tocoma does after observing the larger than typical drop in economy below freezing temperatures. I've also been playing with various settings to see how the onboard computer changes various things.
The reason I ask is that I noticed when switching from Eco Mode to Normal mode while the hvac was set to high auto, there was an audible and felt change in blower motor fan speed, it increased a good bit. I've played with it and have gotten the same result. Especially noticed on front defrost. The only reason I can think of they would program it to do that, is to reduce the load of the alternator while in eco mode, which made me think of this thread. I'd be curious what a voltmeter would say between eco and normal mode.
shackley
www.swxrflab.net
Check if you Toyota APP was open. I had similar issue and narrowed it to the Toyota App. Have to sign out or it pings the truck.
Is this the app on your phone or the truck?
shackley
www.swxrflab.net
Yes - the app does run down the battery if you stay logged in. The same thing happened to my wife's SUV. Since she stopped using the app her battery has not run completely down again. But I think the root cause is that anything can run down the battery when it is kept at such a low state of charge.
It is interesting that this happens with my wife's Lexus battery electric. It has a similar way of charging the 12 volt from the traction battery, and it does not work well either. Lexus just said it is a known problem and that they do not have a fix.
At least the Lexus techs are honest.
shackley
www.swxrflab.net
A trickle charger will definitely do the job. I find it easier to just carry a jump pack so I know the truck will always start. But if you don't charge the 12 volt in a hybrid or carry a jump pack it is just a matter of time until it leaves you stranded IMO.
On another list, someone has been charging through the jump point in the fuse box. That would be easier than getting under the seat every time.
shackley
www.swxrflab.net
You guys could always run generator mode every few days, charge your power stations, work batteries etc. I just idle my TH and make use of the high output inverter when I’m busy driving my work rig for the week/month. Tops of the 12V in the process & keeps the NiMH healthy, engine lubed. Gas is cheap af rn and it sips .20-.50 gal/hr of actual engine runtime
Wouldn't just attaching a trickle charge be easier? That's what we do with the RAV Prime and TH.
evlfred
Monte
Idaho
Had this happen Monday, drove it like normal, parked for an hour came out and turned on accessory power for a minute to power a small camera. After the camera ran an update (2 minutes) Started the truck and all hell broke loose, screens went off, park brake warning came on, wouldn't start. Called Roadside and they said a tow would be by in a couple hours. In the mean time I noticed the tailgate opened really slowly, so I jumped it and the truck started with all kinds of error messages and warning lights. Drove it to toyota and dropped it off and they replaced the battery. Only issue was when I picked it up they didn't clear the DTC's and all the warnings and lights were still there. When they told me I'd need to leave it another day or two to get that addressed I whipped out the Carista and cleared them myself.
Ron
Samsara
I just had my truck at the dealer for a different reason.
They said they had to replace the 12V battery because it didn't have enough charge for their diagnostic/update tools (i forgot the exact term he used).
He said he has not heard about a bad batch of batteries or hybrid not charging the 12V enough. But he said all these newer vehicle have smaller batteries. Seems like replacing batteries under warranty is normal for them. This is a first for me.
NikolaiM
Nikolai
Vancouver
2025 TRD Pro
2024 Limited iForceMAX, 4,000 miles. Went camping over the 4th of July for 5 nights. Did not drive truck during that time. Started 1 time, doors open and shut during the day, same for auto tailgate and power running boards. Go to leave this morning and completely dead, tailgate and power running boards wouldn’t work, no lights on dash. Had to jump it, fired right up and we drove home no problems.
Calling the dealer tomorrow, but doesn’t it seem weird that the truck would not start from the hybrid nor the 12V. Could 5 days or opening doors left power running boards active so they come out when door opened and power tailgate open/close a few different times per day. Could this have killed both batteries or……??
Thanks
I know this is old and I haven't read every reply but when you're camping, could you just leave the truck in "Ready" mode so the truck keeps the battery charged?. I have a 2025 I just picked up and that's my plan for camping
80sguy
Jody
Canda
LC250
Had the factory battery die on me on my LC250 at the airport after a week trip Toyota replaced it on warranty. But it was stressing me out and I am nerd so I built this Spotter — Truck Health Monitor (should work on any TNGA-F)
Tracks a bunch of things including graphing key off 12v Voltage each drive. In building this I do see 14.4 volts key on , engine off because of the dc-dc converter between the Hybrid battery and the 12 volt system.
