Chukwithak
Charlie
ID/CA
25 Undergound DC i-FM OR
Air bags are the way to go !
Air bags are definitely not the way to go if you are off-roading. They do not allow your vehicle the ability to flex. Air bags are meant for the road when driving a road with varying weights. NOT off-road. Your vehicle needs to be able to flex and torque when off-road, hence the purpose of a spring.
CaliTaco64
Hugo
2024 Tacoma trd off road
I have a lift in the back and cradles so my airbags are set up for offroading because they detach and allow for flex. They arent the ones that are solid with the bottom brackets. The solid mounts are not for offroading. I actually went offroading this weekend and ran the truck with no psi unloaded and the truck articulated very well !
kona2chris
Vancouver BC
Hey, newbie here, are you guys all running stock suspension and just adding Dobinson Springs?
andrewleader
Andrew
Washington State
Yep I’m stock shocks with Dobinsons 819V in rear and Alldogs in front with 930 constant extra load, it’s quite good. When doing tough rock crawling, there’s a little extra side to side sway, but otherwise it’s about perfect! When the shocks get older I’ll switch them, I’m just at 20k miles so far. Here’s info on mine: https://tacotunesday.com/build/tacoma-specific.md/suspension
Glizzy
Ian
Park City, UT
2024 Tacoma OR
I installed the Falcon 3.2 kit and Dobinson 819v springs with my GFC. About 1.5" of lift front and 3"-ish rear so it maintains a bit of rake and should handle camping/bike rack load ups for the summer really well I think. The ride quality is a massive upgrade over stock, really loving this kit!
2024 Tacoma Dobinsons Coil Spring Rear Suspension Upgrade (C59-819V) Installed on 2024 TRD Off-Road Longbed 06057EFA-656A-475E-BF48-B1E82A194151
2024 Tacoma Dobinsons Coil Spring Rear Suspension Upgrade (C59-819V) Installed on 2024 TRD Off-Road Longbed D5DEC179_E6B9_4A37_B2A2_6EBA27973593
TacoBirdinNW
2025 DCLB SR5
This was an awesome thread. Thanks for all of the helpful information here guys. I read through this a couple times for info while I was considering my rear setup.
I carry a 400# ish Topo topper on a long bed and ultimately went with the Icon overland springs. With just the topper I'm close to 2" rear lift over stock and once loaded for weekends I'm right around .5" to .75" over stock. Ride is great either way.
Curious though, long term, how have all your shocks held up ? Especially curious about those of you who chose 2+" of rear lift without extended shocks. Even the Bilstein 5100/6100 recommends max rear lift of 1.5" so have wondered about exceeding that spec and what the implications are long term or on rough terrain.
Also a heads up: I got a MUCH smoother ride with extended end links and Bolt On Track Bar Correction Kit. Somewhat inexpensive to get a smooth ride back if you're having any issues there 👌
2024 Tacoma Dobinsons Coil Spring Rear Suspension Upgrade (C59-819V) Installed on 2024 TRD Off-Road Longbed PXL_20260524_222522435.MP
Bendorite
Cory
Bend Oregon
2026 Trailhunter
TH with 819v, tune m1 camper. Springs have settled here after a few trip.
Thanks! Do you have an idea of approximate added weight to the truck? and could you measure center of wheel hub to the fender both front and rear? I have a TH and a Super Pacific build out going on it shortly. Was leaning towards the 819's and getting some real world TH measurements would be great!
hiener
Hien
BC
Tesla
Front 22”
Rear 24 7/8”
was gonna go with super pacific but the tune space we couldn’t be happier. Rip MPG
tune says our build is 575lbs, including hest mattress, truma heater and accessories
Bendorite
Cory
Bend Oregon
2026 Trailhunter
Front 22”
Rear 24 7/8”
Great looking truck and camper! That’s a sweet set up!
thanks for the measurements and details. That should be pretty close for me. Hoping for about an inch lower than you with the extra 150-200lbs. I sit at 23.5 in the rear stock.
Bendorite
Cory
Bend Oregon
2026 Trailhunter
That is almost exactly where I want to be in the rear height wise. Are you still sitting at about that same height? And any idea how much weight you added between the GFC and other gear?
Bendorite
Cory
Bend Oregon
2026 Trailhunter
In that pic I just have the camper (370# ish, 50# of awning, 105# of bike rack). In this pic, I have 260# in the bed. With that and the larger tires, 1.1” taller, I am 1 1/4” above stock height. I was trying to stick w stock suspension in the front as it seems to fit my needs so I think I will need the 817 springs.
Are you still running this setup with the 819's? It is almost exactly what I will be running for weight, and curious about the measurement from rear hub center to the fender flare?
