- First Name
- Rudy
- Joined
- Feb 13, 2026
- Threads
- 13
- Messages
- 257
- Reaction score
- 211
- Location
- New Mexico
- Vehicle(s)
- 2026 Tacoma TRD PRO
No way thats not gonna eat your tires up. There isn't any majic, either its right or its not.
I did multiple alignments and machine shows it’s perfect caster, camber and toe. All 3 have been adjusted to spec and fall within the parameters of the spec sheet that was posted with the trd lift kit posted on this forum.No way thats not gonna eat your tires up. There isn't any majic, either its right or its not.
After specs look great and the photos look great.Finally fixed it! Signed up for an all Toyota tech group on Facebook. A Toyota tech guided me on how to do it and sent me the specs. It’s finally fixed and sitting right. So the Hunter machine has the wrong specs on it. These are the correct specs. You have to manually put them in to the machine.
First pic is the specs the machine needs to be set to.
Second pic is what I was able to get my alignment to. The rest are pics of how my truck is sitting now. The bottom of the tire is now sitting completely flat on the ground. Car drives straight and for some reason my mpgs are back upto 19 mpg.
Dang, 2-2.5 degrees of positive camber is crazy. But honestly, the before photos did look like a lot.Yes I did have to adjust camber and caster the before measurements were highly inaccurate due to the fact that the machine doesn’t let you enter the specs until you have done rolling compensation then measure caster, then you have to go to a very specific place to enter in those specs and then it’ll direct you to new measurements. The real numbers for caster were like 5.0 and camber was 2-2.5.
