Have OEM tonneau installed. Struggling with OEM side bed Molle Install
jcnpkn
RI
Any suggestions on how to be successful? Dealership wants $289 per side to install.
What's the issue?
I don't have the molle panels, but I do have the tonneau cover. Just taking a guess, but could the issue be because the tonneau requires lowering the factory rail?
bigd9247
Dalton
Washington
2024 TRD ORP, 2018 F150 XLT
The OEM tonneau lowers the side bed rails. Is the molle panel compatible with the lowered bed rails? They might not work together.
jcnpkn
jcnpkn
RI
Doesn’t seem to line up but I’m told by dealer that it works and they can do it. I asked if there was a part needed and they seemed to play stupid.
bsquaredMTB
Ben
El Paso, TX
I have the bakflip MX4, which basically mirrors the OEM install. The rails don't have to be lowered on the bakflip MX4 and I'm mostly sure that the OEM doesn't need to lower the rails either, but I could be wrong. That being said, it is a tight squeeze once you try to get the hardware in there to get the molle panels to fit properly. I had the Trumgeta version and it took some effort. At points I had to unhook the tonneau cover clips to slide in the nuts into the rail.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I have another brand of tonneau cover and bedside MOLLE panels. Had to unbolt the cover’s hardware inserted in the bed rail to get the panels attached to holes in the bed under the rails. But we didn’t have to lift the tonneau cover off the bed. Two pairs of hands made it easy.
BIGPZA
Michael
Long Island, NY
2024 TRD Off-Road
Without seeing pictures from inside your bed/the brackets provided with the molle panel, it's tough to offer advice.
My blind guess is that you'd need to modify the brackets so they're able to meet the molle panel at the necessary height to complete the installation. Or, drill new holes in the molle panel to meet the bracket at it's lower height.
I have a rear panel on my truck and had no issues installing, but I don't have an OEM cover, I too have an MX4.
honace
WA
2024 DCLB TRD OR
I have the OEM hard tonneau cover (PT954-35241) and installed it myself on my 24 OR 6' bed. It does lower the factory bed rails about 1/2-3/4" as bed rails are uninstalled and then hung on the tonneau cover aluminum mounting clamps.
rijc99
They are lowered and inwards a little away from the bed wall. Most other covers use the bed rail as their attachment point. So the rail ends up,losing a bit of utility. The OEM one mounts using the factory rail mount holes but as a result requires relocating the rails. This allows full use of the rail.
