Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
Good evening everyone!
Here at Big Dawgs Toyota Tuning we’ve been working on something big that’s almost finished up in production and will be headed to the dyno shortly after that.
Pictured below is an aftermarket throttle body elbow designed by us here at Big Dawgs Toyota Tuning. We’ve increased the diameter on each end by a fair amount, and will have it produced in aluminum.
More to follow on exact specs when we get it in hand. We do know it’s guaranteed fitment based off of singular test piece we had printed.
We’re expecting it to he ready for testing in early June.
2024 Tacoma In development: Throttle Body Elbow for the Toyota 2.4T Engine IMG_3557
GMak621
Røgue Valley
26 Tacoma TRD ØR Hybrid
Nice! How much?
Quez
Nashville
Nice! How much?
Im working that out currently with our manufacturer based off of bulk orders and engraving.
Obviously will depend on how much we’re able to gain from it to make sure the juice is worth the squeeze.
Quez
Nashville
Quick update here: we got our initial test run pieces in. They were a fail. The O ring divot wasn’t big enough & there was no divot for the O ring tail. Also came unmatched. We’re going to rework the CAD on sizing, then look at a new supplier for the time being. We’ll probably look at moving to have them cast instead of printed.
2024 Tacoma In development: Throttle Body Elbow for the Toyota 2.4T Engine IMG_3658
2024 Tacoma In development: Throttle Body Elbow for the Toyota 2.4T Engine IMG_3669
2024 Tacoma In development: Throttle Body Elbow for the Toyota 2.4T Engine IMG_3670
Quez
Nashville
Just for a quick update on this - we got a few revisions done. Going to finalize some slight tweaks, then we'll have a tester printed. Once we verify it fits, we will move on to work on production.
2024 Tacoma In development: Throttle Body Elbow for the Toyota 2.4T Engine IMG_0109
tipsyjam
Hawai'i
Is it cast aluminum or steel or something else?
Has there been consideration as to the fatigue life of the part as it is repeatedly being subject to high pressure air, temperature variation, dynamic loading from the engine movement, throttle body closure pressure spikes, etc.? For instance, we know aluminum fails in fatigue eventually even at pretty small stresses since there is no real fatigue limit. If it is cast this introduces an arguably much worse grain structure that should make it fail sooner due to fatigue. Are there any FEA or some type of analysis results that prove to us this part won't fail anytime soon? And, if it would fail, what we can expect as a typical failure point?
How about the o-ring seal, has there been consideration as to how the part will warp or deform over time due to the stress it will be under and how to ensure the gasket stays sealed?
I ask because the factory part is plastic, right? There's gotta be good reason Toyota did that other than cost and repeatable fabrication. We haven't seen any throttle body failures yet as far as I know, so why move to a cast metal part rather than a more open, better flowing injection molded plastic design? Also, was there any thought as to why Toyota restricted the inlet size in the first place and if it is safe to increase the size of it without other supporting mods?
Miqie
2024 TRD Sport-Bronze oxide.
So for the uniformed, how will this help the engine? More HP? If so how much?
Will721
Will
Quad Cities
2025 TRD OR
Toyota 100% only used plastic due to cost. Coming from the diesel world, cast aluminum does just fine in these applications. Really the only benefit to plastic over aluminum is thermal insulation. Aluminum will hold heat longer. But aluminum has the benefit of being more durable over time as heat cycled plastic becomes brittle. Plus the main reason most boost related components in automotive applications tend to be metal is it can withstand much higher boost pressures.
Ive been watching various manufacturers race to make power mods for these engines. Its very possible we will soon be at the point where the non hybrid trucks will make 500hp with just bolt ons. There's only one way that will happen, more boost.
