JBL Sound System Upgrade?
jayvee
Javier
Los Angeles
2024 Tacoma SR5
so...its worth the cost? I've seen the TacoTunes kit, Beat Sonic and the Orella amp. I want more bass but I don't want to lose clarity. I've got money (or can save it) which kit offers the better option? Assume that the Orella route comes with just the amp Also assume that the Beat Sonic comes with the amp and 2 power seat apadters powering 2 JBL underseat subs.
If anyone can answer that, i'd appreciate it.
There have been some advances on updating the JBL sound system but some of the products are pending launch. AudX is working on a plug and play harness that will allow you to use any DSP amplifier of your preference and will retain the voice prompts you loose with the Orella. They estimate the harness will be available in early may and will be available on their website. www.audxsound.com
Koryota
Paul
www.paulbae.com
Orella is one sale away from being easily worth the cost in my opinion. The Match amp they're using is in another league compared to TacoTunes or Beat Sonic. It also has a 9th DSP channel (w/RCA out) so you can add an external sub setup of your choice. You will have to bust out a laptop & use their software to set the crossover & activate the 9th channel or find a local Audiotec Fischer dealer to do that for you. Just the amp by itself will give you much cleaner sound but you will be limited by your oem speakers at that point.
You could piece a system like this together, but you'll end up spending a lot of money either way & time learning to play with the DSP settings for each channel on a laptop.
I've installed the older version of this (PP86DSP) in my own & friends' BMWs + 1 Porsche without upgrading the speakers and was very happy with the results.
Koryota
Paul
www.paulbae.com
Oh, you lose the voice command function with the Orella kit? I was not aware of this from looking at their website.
jayvee
Javier
Los Angeles
2024 Tacoma SR5
Yes, the Orella harness does not connect to the voice prompt signal it bypasses it.
762_NateOh
Nate
Florida Panhandle
Not to hijack, but I'm also looking to make a little audio tweak. I'm looking to get everything a little brighter.
I was thinking about incrementally replacing speakers, starting with the dash 3.5's.
Has anyone gone down that route and have any speakers to recommend. I have the JBL amplified system.
Luke1
Luke
Illinois
2025 Tacoma TRD Sport
Same, I swapped my tweeters but still lacking in mid/high. Wondering if also swapping the 3.5’s would do anything or I need to add an amp too.
I wouldn't be surprised if you upgrade speakers and it actually sounds worse. If you're upgrading the speakers, you need to replace the amplifier. You're increasing the RMS of the speakers, without increasing the power output.
In other words, it would be like upgrading your sprinkler system by getting larger (more powerful) heads and increasing the diameter of the piping (more flow), but not increasing (upgrading) the pump or system (amplifier) that drives the water. You'll just get a trickle of water out.
Luke1
Luke
Illinois
Makes sense, my idea was to steal a bit of the power from the rest of the system and give it to the tweeters to improve the highs by dropping the ohm rating of the tweeters a bit. Might’ve made it a bit better but nothing significant.
Koryota
Paul
www.paulbae.com
Upper tweeter frequency is mostly covered by the A-pillar tweeters so the 3.5's won't help much. I wasn't able to find any RTA measurements taken from the current model Tacoma or 4Runner, but I'm going to guess that the 3.5's are crossed between 400hz to 3Khz.
It should be possible making JBL sound more brighter by replacing just the tweeters with an aftermarket set with very high sensitivity like 95db+.
If I were to try this, I would remove the oem JBL tweeter & measure its Re (DC resistance) with a DMM. If it reads around 3.2-3.6ohms, it's a 4ohm speaker so I would shop for 4ohm tweeters. If it's not a 4ohm tweeter, I would not go any further.
Before I slap them on, I would solder a capacitor on the positive lead for a 3-4Khz high pass.
Drifte
Colton
Iowa
I was hopefull the JBL system would be a little better. It seems the IB 10" is just too light duty to do much (must have 1/4" ptp excursion?!). I have the Tacotunes enclosure ordered to replace the JBL sub. I dont typically buy premade boxes of unknown tuning, but this was a really tight spot. I would like to measure the truck with the minidsp now and then after with the Tacotunes sub in. The next step would be finding an easy way to cut-off some bass going to the front door speakers, trying to keep it all cheap/simple.
If this doesnt do it, I may have to go to Orella or Audx...but Im hopefull this will be enough to save me all that time and money.
2024 Tacoma JBL Sound System Upgrade? Screenshot_20260424_154037_Chrom
jayvee
Javier
Los Angeles
2024 Tacoma SR5
The JBL system upgrade harness from AudX is now available. I know some will complain about the price but before you voice your dislike on price check the quality, competing product availability and the amount of time it will save you to upgrade your system.
https://www.audxsound.com/products/tyaih22uf10
2024 Tacoma JBL Sound System Upgrade? TYAIH22UF10
OGC3102
Omar
2026 Tacoma TRD-Offroad Hybrid
I forget how new our vehicles are, lol thanks for sharing the link for the harness I was searching everywhere for something plug and play for my hybrid with the jbl now I can reuse my old sound system
