lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Pic on their website shows it hanging below the frame, I don't know how a skid plate would fit? For that reason alone its a no-go for me.
It will suck if folks have to remove or cut part of a skid plate. My TH doesn’t have anything over its tank.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Not concerned about the skid plates, the huge 30gal tank hanging below the frame is what is concerning to me.
Gaspe
Tim
Vermont
2026 TRD OR Tacoma (Bronze); Sprinter 4x4; Subi Outback/Wilderness; Mustang '66
I don't believe it said that. I thought it said it used factory strap mounting locations, but not the factory straps.
You are correct. Thank you for the clarification/correction.
Gaspe
Tim
Vermont
Love the idea of a larger tank. But a few notes from LRA’s website regarding this tank concern me:
1. Loss of 1/2” ground clearance compared to factory tank
2. No skid plate required
3. Constructed from durable 2mm aluminized steel
Trying to wrap my head around why a tank hanging 1/2” lower, with a wall only 2mm thick, doesn’t require a skid plate……
lauren01
Lauren
Ventura, CA USA
They seem to be indirectly indicating that the tank is sturdy enough not to need an additional layer.
Yeah, that is what I thought too. That is quite a claim for an aluminum fuel tank that to me seems to be vulnerable. I assume there will be more information coming as the delivery date gets closer.
spyderdrifter
Tom
somewhere in CO
2025 Limited
Not that I believe everything online, or Wikipedia, but based on what LRA states, it is still a steel tank, not an aluminum one. That would be why it doesn't outright requre a skid plate. That being said, anyone with proper fabrication skills and tools would be able to build their own skid plates if they really wanted to. I'd be more interested in knowing how much of the 2mm thickness is steel, and how think the aluminum coating is.
2024 Tacoma Long Range America Fuel Tank on 4th Gen Tacoma
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
When you add the weight of the truck and some nasty rocks .070" isn't very much at all. What makes it worse is how far it hangs below the frame, looks just like a skid plate except its full of gas.
If they say its strong enough then you should be able to stick a badlands jack underneath it as a jacking point.
