OEM TRD Lift Components Question
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Ok, after a lot more time with these... 100% recommend. I would go as far as saying mandatory parts for any lift / suspension upgrade. Turning radius is WAY better. Steering is direct and precise. Far sportier than the original feel.. No funny sounds at all after 200 miles of rough terrain in the desert this weekend.
frosty4x4
Midwest
Great to hear! Would the parts you used fit an Off-road 6MT?
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Looking at the pdf above... the difference on the 6spds seems to be different rear springs.. These parts ( lower knuckle and tie rods) are all the same part number for every trim, except the sr5s which have the 86 spec knuckle.
frosty4x4
Midwest
Ah good to know thank you. OP should sticky this so people can just grab the part numbers based on sr5 or not.
rijc99
Toyota killed these part numbers. Any idea if the TRD Pro tie rods are the same as the ones in this kit?
Jon
Charlotte, NC
2025 Bronze Oxide TRD Off Road iForce Max
I second this. I couldn’t find the tie rods anymore. Only the lower knuckle attachments.
Jon
Charlotte, NC
I might be mistaken but it looks like it might be backwards. The 91 spec are the only ones for SR5 short bed and long bed, all the other trims use 86 spec.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
My dealership messed up and thought I never picked up my knuckle / tie rod order back in April so now I have another set if anyone needs, dm me. Gas off road trim.
